Re: Cervini shaker hood kit
[Re: IMGTX]
#3180618
10/03/23 02:54 PM
10/03/23 02:54 PM
Posts: 4,680 Wichita
GY3
Wichita
I have not tried the kit but the factory hoods were metal.
Nearly all mopar hoods were metal. AAR, T/A, six pack road runner & coronets (1969 only I believe, feel free to correct), and the Chrysler 300 Hurst edition are the only fiberglass ones I remember on production cars.
Probably more I do not know but not many. Then you have aluminum hoods in '63 and '64.
[Re: moparx]
#3180925
10/04/23 12:24 PM
10/04/23 12:24 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have also been looking to convert my 12' to a Shaker hood to match my 70.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Wirenut]
#3181071
10/04/23 07:08 PM
10/04/23 07:08 PM
Posts: 11,077 Berlin, N.J.
abodyjoe
Berlin, N.J.
Has anyone tried one of these? Issues ? Thoughts .
Are the factory hoods glass ? they have been making high quality hoods for mustangs forever, don't see why quality wouldn't be there for challengers too..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: GarageDodge]
#3181291
10/05/23 10:46 AM
10/05/23 10:46 AM
Posts: 630 Ct
Wirenut
Ct
we put one on my sons 2013 rt challenger high quality,fit&finish very good,&it has a cold air intake that works. Thanks . Do you think it’s much heavier than the stock hood?
[Re: Wirenut]
#3181323
10/05/23 12:18 PM
10/05/23 12:18 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
Are the factory hoods glass ? Stock factory Challenger hoods are aluminum
[Re: Wirenut]
#3181334
10/05/23 12:48 PM
10/05/23 12:48 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
we put one on my sons 2013 rt challenger high quality,fit&finish very good,&it has a cold air intake that works. Thanks . Do you think it’s much heavier than the stock hood? Sorry I thought you were asking about the Gen 1 Challengers not the Gen 3. My bad.
[Re: Wirenut]
#3181515
10/05/23 09:28 PM
10/05/23 09:28 PM
Posts: 195 Charlton,Ma
Adm413
Charlton,Ma
Are the factory hoods glass ? I put one of these hood kits on my 09 SRT within a year of buying it new, so it is now 13+ years old. It is a good quality kit but I have had a couple issues. First was that it was damaged during shipping. I refused it and sent it back and they immediately sent me a new one. Good service on their part. I bought it color match painted and it did match perfectly. The bad issues I had with it are original shaker screws attaching the base plate to the top would vibrate loose. I had to replace them with screws and lock washers and have had no issues since. The other issue is the base plate for the shaker has pedestals that sit on top of intake. They are molded plastic and the engine heat with the combination of the shaker scoop weight caused them to bow down. So the driver side with the tallest pedestal sags down and the shaker now is a little tilted. I have thought about seeing if I could order just the base to fix it but just haven't gotten around to that. I'm not sure if Cervini's has had an issue with other ones or not but it is possible they may have strengthened that design. Overall I have been happy with the hood. I bought this kit before Mopar even came out with the shaker on these newer Chalengers. Here is my red one next to a factory shaker car.
1970 GTX 440/727, B5/B5
1970 Barracuda conv. 318/3spd, EW1/R4
1974 Cuda 383/727, FM3/X9
1971 Barracuda 318/727, GK6/X9
1966 Coronet 500 413/727,White/Black
2010 Challenger SRT 6.1/6Spd, Tor-red/black
[Re: GarageDodge]
#3181705
10/06/23 02:23 PM
10/06/23 02:23 PM
Posts: 630 Ct
Wirenut
Ct
Yes it is about 30 lbs more,than stock hood. Wow . More than I would have thought.
[Re: Adm413]
#3181706
10/06/23 02:24 PM
10/06/23 02:24 PM
Posts: 630 Ct
Wirenut
Ct
Are the factory hoods glass ? I put one of these hood kits on my 09 SRT within a year of buying it new, so it is now 13+ years old. It is a good quality kit but I have had a couple issues. First was that it was damaged during shipping. I refused it and sent it back and they immediately sent me a new one. Good service on their part. I bought it color match painted and it did match perfectly. The bad issues I had with it are original shaker screws attaching the base plate to the top would vibrate loose. I had to replace them with screws and lock washers and have had no issues since. The other issue is the base plate for the shaker has pedestals that sit on top of intake. They are molded plastic and the engine heat with the combination of the shaker scoop weight caused them to bow down. So the driver side with the tallest pedestal sags down and the shaker now is a little tilted. I have thought about seeing if I could order just the base to fix it but just haven't gotten around to that. I'm not sure if Cervini's has had an issue with other ones or not but it is possible they may have strengthened that design. Overall I have been happy with the hood. I bought this kit before Mopar even came out with the shaker on these newer Chalengers. Here is my red one next to a factory shaker car. Thanks for sharing . Found a really good deal on one locally, but maybe I should hold out for oem
