Pros and cons of using Chevy sized rods in hemi build #3170970
08/28/23 08:21 AM
08/28/23 08:21 AM
Berlin NJ
scottk Offline OP
scottk  Offline OP
Berlin NJ
Hi. Getting ready to order some parts. Have a 4.5 bore Hemi block and some Diamond pistons for 4.25 stroke. They have .990 pins. Wondering if using the .220 rod size has any advantages? Less or no clearancing in the block? Is the Chevy size weaker because it is smaller? Just trying to weigh things out. Thanks.
Re: Pros and cons of using Chevy sized rods in hemi build [Re: scottk] #3170985
08/28/23 09:02 AM
08/28/23 09:02 AM
an8sec70cuda Offline
No cons. All pros. Less weight, more clearance, more options, plenty strong.
I have BB Chevy rods in my 575" hemi.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pros and cons of using Chevy sized rods in hemi build [Re: an8sec70cuda] #3171003
08/28/23 09:49 AM
08/28/23 09:49 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Exactly what Chip said, plus you have more bearing choices available. And less grinding on the block.
Brian
Re: Pros and cons of using Chevy sized rods in hemi build [Re: '72CudaRacer] #3171015
08/28/23 10:23 AM
08/28/23 10:23 AM
NC
440Jim Offline
440Jim  Offline
NC
For what you are doing, the others have said it well.
I use cranks with the journal width for Chevy rod, but there are some 2.2 bearing rods with Mopar width if that is what your crank has. I won't comment on if the excessive side clearance with Chevy rod width on Mopar journal width is or is not a problem.
Re: Pros and cons of using Chevy sized rods in hemi build [Re: 440Jim] #3171020
08/28/23 10:42 AM
08/28/23 10:42 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
the 2.200 is plenty strong and there are a lot more mopar length or longer rods today that have the proper mopar width. Back in the day all there was was the Eagle 7.100 which was basically a BB Chevy rod.
The key with Hemis is the pistons are HEAVY but stroking them shortens the compression height and decreases the bobweight considerably. Should be no issues.
WIZE
In Car:
Re: Pros and cons of using Chevy sized rods in hemi build [Re: 440Jim] #3171021
08/28/23 10:47 AM
08/28/23 10:47 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
As already said, you don't use Mopar rod (or pin) sizes anymore. Too many advantages to using Chevy rods. Stroke clearance, weight, bearing sizes, availability, price. Rod choices, price, availability. Come on and join the 21st century. And, no, I wouldn't think about using them on a Mopar width journal.
2011 Drag Pak Challenger
Re: Pros and cons of using Chevy sized rods in hemi build [Re: rickseeman] #3171038
08/28/23 11:34 AM
08/28/23 11:34 AM
Berlin NJ
scottk Offline OP
scottk  Offline OP
Berlin NJ
Great answers. Thanks for the input.
Re: Pros and cons of using Chevy sized rods in hemi build [Re: scottk] #3171054
08/28/23 12:21 PM
08/28/23 12:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Reduced rod journal diameter reduces journal overlap and makes the crankshaft more flexible (so does a stroke increase).
Not enough to worry about.
Boffin Emeritus
Re: Pros and cons of using Chevy sized rods in hemi build [Re: polyspheric] #3171180
08/28/23 06:59 PM
08/28/23 06:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you don't have the crankshaft yet, check into getting it with chevy width rod journals as well as diameter. THen you can use chevy rods. Sometimes they are cheaper and easier to get than Mopar rods with Chevy journal diameter but Mopar width.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Pros and cons of using Chevy sized rods in hemi build [Re: polyspheric] #3171202
08/28/23 08:18 PM
08/28/23 08:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That would be my thinking.
On a SB Mopar stroker, I was liking 2.0 chevy rods, but keep the big 360 mains, to try and get the best of both worlds.
