Pros and cons of using Chevy sized rods in hemi build
#3170970
08/28/23 08:21 AM
08/28/23 08:21 AM
Posts: 657 Berlin NJ
scottk
Berlin NJ
Hi. Getting ready to order some parts. Have a 4.5 bore Hemi block and some Diamond pistons for 4.25 stroke. They have .990 pins. Wondering if using the .220 rod size has any advantages? Less or no clearancing in the block? Is the Chevy size weaker because it is smaller? Just trying to weigh things out. Thanks.
Re: Pros and cons of using Chevy sized rods in hemi build
[Re: scottk]
#3170985
08/28/23 09:02 AM
08/28/23 09:02 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
No cons. All pros. Less weight, more clearance, more options, plenty strong. I have BB Chevy rods in my 575" hemi.
[Re: 440Jim]
#3171021
08/28/23 10:47 AM
08/28/23 10:47 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
As already said, you don't use Mopar rod (or pin) sizes anymore. Too many advantages to using Chevy rods. Stroke clearance, weight, bearing sizes, availability, price. Rod choices, price, availability. Come on and join the 21st century. And, no, I wouldn't think about using them on a Mopar width journal.
2011 Drag Pak Challenger
[Re: scottk]
#3171054
08/28/23 12:21 PM
08/28/23 12:21 PM
Posts: 4,206 New York
polyspheric
New York
Reduced rod journal diameter reduces journal overlap and makes the crankshaft more flexible (so does a stroke increase). Not enough to worry about.
Boffin Emeritus
[Re: polyspheric]
#3171180
08/28/23 06:59 PM
08/28/23 06:59 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
If you don't have the crankshaft yet, check into getting it with chevy width rod journals as well as diameter. THen you can use chevy rods. Sometimes they are cheaper and easier to get than Mopar rods with Chevy journal diameter but Mopar width.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: polyspheric]
#3171202
08/28/23 08:18 PM
08/28/23 08:18 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Reduced rod journal diameter reduces journal overlap and makes the crankshaft more flexible (so does a stroke increase). Not enough to worry about. That would be my thinking. On a SB Mopar stroker, I was liking 2.0 chevy rods, but keep the big 360 mains, to try and get the best of both worlds.
