EFI #3168300
08/16/23 02:58 PM
08/16/23 02:58 PM
kentucky
b body idiot Offline OP
kentucky
Thinking of putting a EFI on a 69 Superbee 440 4spd . Wondering whats out there that is compatiable. Really just wondering what kind of recommendations from people who are running a EFI. Thanks
Re: EFI [Re: b body idiot] #3168302
08/16/23 03:05 PM
08/16/23 03:05 PM
AndyF Offline
AndyF  Offline
The best entry level EFI setup is the Holley Sniper. It isn't really a bolt on kit since you have to upgrade the fuel system, change some wiring and modify the ignition system. A complete Sniper install is more than most "backyard" guys can handle but it doesn't really need professional install, it just needs someone who has plenty of tools and plenty of knowledge.
I have a bunch of Sniper videos on my youtube channel.
https://www.youtube.com/channel/UCoSY4bQ7I23XK834NLVTC9w
Re: EFI [Re: AndyF] #3168315
08/16/23 03:50 PM
08/16/23 03:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Then there are those of us that prefer the most in the weeds approach Microsquirt/Megasuirt.
Re: EFI [Re: Sniper] #3168325
08/16/23 04:19 PM
08/16/23 04:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
OR even worser ,,, an 8 Stack EFI on a street car LOL
Re: EFI [Re: CSK] #3168340
08/16/23 05:33 PM
08/16/23 05:33 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Or you can go the 6 pac route....F&B throttle bodies set up and FAST ECU.
Running that combo on my 440 for eight years now, with only a leaky AN fitting.
My Monster are real!
Living within your means makes life pretty easy.
Re: EFI [Re: CSK] #3168359
08/16/23 07:32 PM
08/16/23 07:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Dual throttle bodies on a flathead six for me. I guess I could go three throttle bodies, it only has three intake ports, lol.
Re: EFI [Re: b body idiot] #3168493
08/17/23 12:04 PM
08/17/23 12:04 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I used Holley Terminator X Stealth 4150 with the in tank module.
I used my existing ignition but upgraded the FBO module and coil. Also with Holley in tank pump module no return line needed or regulator. Easy peasy!
Re: EFI [Re: b body idiot] #3168797
08/18/23 12:56 PM
08/18/23 12:56 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I'm using a base model Sniper on a 512. The fuel system was the biggest issue. If an EFI ready tank is available for your car them that is what I would do. Saves lots of hassle with fabrication.
Re: EFI [Re: MarkZ] #3168802
08/18/23 01:25 PM
08/18/23 01:25 PM
Andrewh Offline
Andrewh  Offline
or use a surge tank setup instead.
I would probably have prefered intank, but they don't make one and cutting up a new tank didn't seem like a good idea at the time.
Re: EFI [Re: Andrewh] #3168826
08/18/23 02:11 PM
08/18/23 02:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That's the route I am going with my 51, no EFI tank and I don't see a need to cut up my original or buy a reproduction one, that may or may not fit properly.
Here's the idea I am going with
http://madscientistmatt.blogspot.com/2005/12/surge-overkill.html
Re: EFI [Re: Sniper] #3168991
08/19/23 10:16 AM
08/19/23 10:16 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Plus it is port injection instead of throttle body. If i was going to efi that's what i would choose.
Re: EFI [Re: Moparite] #3168996
08/19/23 10:36 AM
08/19/23 10:36 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Moparite
Quote
Why?
Engine masters did a dyno test and the TBI actually made a hair more power due to the cooing effect brought on by the latent heat of evaporation, same reason a carb seems to make more HP than MPI.
Unless you can tune each injector to the specific cylinder's need to balance out the AFR then it is a waste of time, money and effort.
An article to consider
https://www.enginelabs.com/news/dyno-comparison-of-holley-tbi-and-mpi-systems-on-800-hp-big-block/
Re: EFI [Re: Sniper] #3169175
08/20/23 11:31 AM
08/20/23 11:31 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I believe i saw that one, And they did mention the intake used makes a difference. Since there is no kegger style intakes you are stuck using aftermarket intakes made for carburetors. The mod man intake is about the closest to a kegger style and would like to see how it would perform with mpi.
Re: EFI [Re: Moparite] #3169186
08/20/23 12:28 PM
08/20/23 12:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Why would you want to use a "kegger style intake".
A 440 doesn't need help making torque,
Re: EFI [Re: Moparite] #3169228
08/20/23 03:11 PM
08/20/23 03:11 PM
AndyF Offline
AndyF  Offline
I ran port injection on my Duster. Really no difference in power for the average street engine between port injection and throttle body. The EFI setup on my Duster cost about $10,000 while the Sniper setup on my Coronet is around $2500. The Coronet engine actually made a little better power than the Duster engine. The port injection systems are probably higher quality and more reliable than the Sniper setup but there is a lot of cost associated with going to port injection.
Re: EFI [Re: AndyF] #3169231
08/20/23 03:13 PM
08/20/23 03:13 PM
AndyF Offline
AndyF  Offline
Had a customer come in recently who wanted to put an 8 stack setup on a Ford FE engine. Told him that it would cost about $10,000, it would be unreliable, and that he would eventually grow to hate it, but if that is what he wanted we could do it.
Re: EFI [Re: AndyF] #3169258
08/20/23 04:15 PM
08/20/23 04:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I love my 8 stack setup. drive it everywhere, runs & drives like a stock 440 , BUT if you dont know how to work on them, [ have to pay someone to dial it in] you are 100% correct, it took a lot of trial and error to get it good, just got back from a 25 mile drive, AC blowin cold & 110deg outside. LOVE IT smile , the BEST thing I did to make it work better is a NON Contact TPS, WORLD of difference .
Re: EFI [Re: AndyF] #3169334
08/20/23 11:04 PM
08/20/23 11:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Does he want it to be mechanical stack injection or EFI stack injector system? work
I've seen more than one BB and street hemi Mopar in SO CA that had EFI stack injection that the owners said they love them, and they were way better than before with carburetors : :workshruggy
