Re: EFI
[Re: b body idiot]
#3168302
08/16/23 03:05 PM
08/16/23 03:05 PM
Posts: 31,050 Oregon
AndyF
The best entry level EFI setup is the Holley Sniper. It isn't really a bolt on kit since you have to upgrade the fuel system, change some wiring and modify the ignition system. A complete Sniper install is more than most "backyard" guys can handle but it doesn't really need professional install, it just needs someone who has plenty of tools and plenty of knowledge. I have a bunch of Sniper videos on my youtube channel. https://www.youtube.com/channel/UCoSY4bQ7I23XK834NLVTC9w
Re: EFI
[Re: Sniper]
#3168325
08/16/23 04:19 PM
08/16/23 04:19 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Then there are those of us that prefer the most in the weeds approach Microsquirt/Megasuirt. OR even worser ,,, an 8 Stack EFI on a street car LOL
Re: EFI
[Re: CSK]
#3168340
08/16/23 05:33 PM
08/16/23 05:33 PM
Posts: 4,771 Star Idaho
67vertman
Star Idaho
Or you can go the 6 pac route....F&B throttle bodies set up and FAST ECU.
Running that combo on my 440 for eight years now, with only a leaky AN fitting.
My Monster are real!
Living within your means makes life pretty easy.
Re: EFI
[Re: CSK]
#3168359
08/16/23 07:32 PM
08/16/23 07:32 PM
Posts: 6,289 nowhere
Sniper
nowhere
Then there are those of us that prefer the most in the weeds approach Microsquirt/Megasuirt. OR even worser ,,, an 8 Stack EFI on a street car LOL Dual throttle bodies on a flathead six for me. I guess I could go three throttle bodies, it only has three intake ports, lol.
Re: EFI
[Re: b body idiot]
#3168797
08/18/23 12:56 PM
08/18/23 12:56 PM
Posts: 4,439 Michigan
MarkZ
Worthy
Worthy
Thinking of putting a EFI on a 69 Superbee 440 4spd . Wondering whats out there that is compatiable. Really just wondering what kind of recommendations from people who are running a EFI. Thanks I'm using a base model Sniper on a 512. The fuel system was the biggest issue. If an EFI ready tank is available for your car them that is what I would do. Saves lots of hassle with fabrication.
Re: EFI
[Re: Andrewh]
#3168826
08/18/23 02:11 PM
08/18/23 02:11 PM
Sniper
nowhere
or use a surge tank setup instead. I would probably have prefered intank, but they don't make one and cutting up a new tank didn't seem like a good idea at the time. That's the route I am going with my 51, no EFI tank and I don't see a need to cut up my original or buy a reproduction one, that may or may not fit properly. Here's the idea I am going with http://madscientistmatt.blogspot.com/2005/12/surge-overkill.html
Re: EFI
[Re: Sniper]
#3168991
08/19/23 10:16 AM
08/19/23 10:16 AM
Posts: 992 rust belt
Moparite
rust belt
Or you can go the 6 pac route....F&B throttle bodies set up and FAST ECU. Plus it is port injection instead of throttle body. If i was going to efi that's what i would choose.
Re: EFI
[Re: Moparite]
#3168996
08/19/23 10:36 AM
08/19/23 10:36 AM
Sniper
nowhere
Or you can go the 6 pac route....F&B throttle bodies set up and FAST ECU. Plus it is port injection instead of throttle body. If i was going to efi that's what i would choose. Why? Engine masters did a dyno test and the TBI actually made a hair more power due to the cooing effect brought on by the latent heat of evaporation, same reason a carb seems to make more HP than MPI. Unless you can tune each injector to the specific cylinder's need to balance out the AFR then it is a waste of time, money and effort. An article to consider https://www.enginelabs.com/news/dyno-comparison-of-holley-tbi-and-mpi-systems-on-800-hp-big-block/
Re: EFI
[Re: AndyF]
#3169258
08/20/23 04:15 PM
08/20/23 04:15 PM
CSK
Pattison Texas
Had a customer come in recently who wanted to put an 8 stack setup on a Ford FE engine. Told him that it would cost about $10,000, it would be unreliable, and that he would eventually grow to hate it, but if that is what he wanted we could do it. I love my 8 stack setup. drive it everywhere, runs & drives like a stock 440 , BUT if you dont know how to work on them, [ have to pay someone to dial it in] you are 100% correct, it took a lot of trial and error to get it good, just got back from a 25 mile drive, AC blowin cold & 110deg outside. LOVE IT , the BEST thing I did to make it work better is a NON Contact TPS, WORLD of difference .
