727 transmision slip yok question
#3160731
07/18/23 08:47 PM
07/18/23 08:47 PM
Posts: 710 St Louis, MO 63026
convx4
St Louis, MO 63026
Good day all I have a drive shaft from a 60's c-body that I am shorting. It has an inertia ring and 1330 end yoke on the transmission end. It did not come with the slip yoke. I found this DANA SPICER 2-3-14031X slip yoke at Dennys drive shafts. It states that it will not fit a 727 or 833. It looks like it should fit, given the listed dimensions, see link. https://www.dennysdriveshaft.com/p1...ip_yoke_1330_series_29_based_on_30_.htmlSo why wont it fit in a 727? I trust Denny's Drive shafts, mostly because other sites list it as fitting the 727. A 7290 727 slip yoke and the 5-7437x conversion u-joint will take care of my issue, just hoping to keep it simple. Any one have any input?
Re: 727 transmision slip yoke question
[Re: convx4]
#3160762
07/18/23 09:50 PM
07/18/23 09:50 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
OK now I see that the inside spline diameter on the 7290 yoke is 1.312" and the 1330 is 1.284" So the yoke I'm after is .028" smaller.
So grinding the ID larger on the 1330 will not guarantee it will fit and hold up? Why would you even consider that. Just get the correct yoke and your golden.
[Re: convx4]
#3160823
07/19/23 02:36 AM
07/19/23 02:36 AM
Posts: 43,269 Bend,OR USA
Cab_Burge
So grinding the ID larger on the 1330 will not guarantee it will fit and hold up? How badly do you want to get hurt when that type of mod fails?
Re: 727 transmision slip yok question
[Re: convx4]
#3160953
07/19/23 12:21 PM
07/19/23 12:21 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The spline angle on later 30-spline slip yokes is different. In pic below the 727 is on the left.
[Re: Alaskan_TA]
#3160957
07/19/23 12:25 PM
07/19/23 12:25 PM
Posts: 19,555 north of coder
moparx
now for the "old man stoopid question of the day".............. why do the 7260 and 7290 yolks have a longer snout length than the 1350 yolk ? what do i not get here ?
[Re: moparx]
#3161343
07/20/23 02:56 PM
07/20/23 02:56 PM
John_Kunkel
Rio Linda, CA
Most factory slip yokes have a spline-less area inside at the front to accommodate a seal on the output shaft that was used for a few years (see my pic above). Aftermarket yokes usually don't.
