A look inside a Pro-Flite #3155327
06/29/23 05:47 PM
06/29/23 05:47 PM
MI, usa
dvw Online content OP
dvw  Online Content OP
MI, usa
Refreshing a Pro-Flite. Thought it might be interesting to see the guts. Nice parts for sure. It's a morph between 727 and 9904. Case, shafts, pump, and low roller are 727 based. Pump and case are modified to accept 904 drums, planets and bands. 6 pin planets, lots of billet aluminum goodies. Aluminum park gear. Servos are stock. I pull the VB apart to clean. Dave says he doesn't use fancy clutch frictions or Kolene steels.
Doug
Re: A look inside a Pro-Flite [Re: dvw] #3155331
06/29/23 05:55 PM
06/29/23 05:55 PM
MI, usa
MI, usa
Next pics
Re: A look inside a Pro-Flite [Re: dvw] #3155363
06/29/23 07:15 PM
06/29/23 07:15 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's a Powerglide splined input shaft and stator support?
Alan Jones
Re: A look inside a Pro-Flite [Re: LA360] #3155412
06/29/23 09:11 PM
06/29/23 09:11 PM
A727Tflite Offline
A727Tflite  Offline
Wonder how much it has changed over the last 45 years.
Re: A look inside a Pro-Flite [Re: dvw] #3155413
06/29/23 09:22 PM
06/29/23 09:22 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Those guts are in more stock eliminator cars you can shake a stick at….. and NOT just Mopars!
We cruised through this one after a driveline shock episode…. all was well.
Re: A look inside a Pro-Flite [Re: J_BODY] #3155475
06/30/23 06:07 AM
06/30/23 06:07 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Very cool to see. Thanx for sharing!
Re: A look inside a Pro-Flite [Re: STEFF] #3155497
06/30/23 09:04 AM
06/30/23 09:04 AM
PA
moparacer Offline
moparacer  Offline
PA
Looks like the steel's are starting to wear on that aluminum drum pretty good. Might take a file and knock the edges off a little.
Dealt with that on glides and the reverse clutch steel's. Have to put case savers in when it gets bad enough.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: A look inside a Pro-Flite [Re: moparacer] #3155502
06/30/23 09:34 AM
06/30/23 09:34 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Is that ‘Dave’ from State Farm? What’s his charge for a trans or parts to install?
Re: A look inside a Pro-Flite [Re: cudaman1969] #3155506
06/30/23 10:10 AM
06/30/23 10:10 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I LOVE this stuff! His list of available ratios is mind blowing! Thanks for sharing.
Re: A look inside a Pro-Flite [Re: cudaman1969] #3155521
06/30/23 11:19 AM
06/30/23 11:19 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you gotta ask......It depends on the final intended use of the trans. Big difference between a low HP stocker and a factory shoot out application(although those are Joel's on Joy Versions). Also the term proflite gets tossed around alot but a few sources make similar transmissions Pro Trans, A1, Joels on Joy, A&A, Coan all make versions of them .
Re: A look inside a Pro-Flite [Re: Al_Alguire] #3155541
06/30/23 12:27 PM
06/30/23 12:27 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks so much for taking the time to share these photos with us.
I have known of these transmissions for years but never got to see the insides of one.
Re: A look inside a Pro-Flite [Re: 340Cuda] #3155622
06/30/23 04:15 PM
06/30/23 04:15 PM
Canada
RobR Offline
RobR  Offline
Canada
Very Nice...
Re: A look inside a Pro-Flite [Re: RobR] #3155629
06/30/23 04:55 PM
06/30/23 04:55 PM
MI, usa
MI, usa
Called Dave yesterday with a few questions. Nice guy and easy to get info from. Personally with Joel, smartest trans guy I've ever met in person.
Doug
