A look inside a Pro-Flite
#3155327
06/29/23 05:47 PM
06/29/23 05:47 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Refreshing a Pro-Flite. Thought it might be interesting to see the guts. Nice parts for sure. It's a morph between 727 and 9904. Case, shafts, pump, and low roller are 727 based. Pump and case are modified to accept 904 drums, planets and bands. 6 pin planets, lots of billet aluminum goodies. Aluminum park gear. Servos are stock. I pull the VB apart to clean. Dave says he doesn't use fancy clutch frictions or Kolene steels. Doug
Re: A look inside a Pro-Flite
[Re: dvw]
#3155331
06/29/23 05:55 PM
06/29/23 05:55 PM
dvw
MI, usa
Next pics
[Re: STEFF]
#3155497
06/30/23 09:04 AM
06/30/23 09:04 AM
Posts: 2,516 PA
moparacer
PA
Looks like the steel's are starting to wear on that aluminum drum pretty good. Might take a file and knock the edges off a little.
Dealt with that on glides and the reverse clutch steel's. Have to put case savers in when it gets bad enough.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: cudaman1969]
#3155521
06/30/23 11:19 AM
06/30/23 11:19 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Is that ‘Dave’ from State Farm? What’s his charge for a trans or parts to install? If you gotta ask......It depends on the final intended use of the trans. Big difference between a low HP stocker and a factory shoot out application(although those are Joel's on Joy Versions). Also the term proflite gets tossed around alot but a few sources make similar transmissions Pro Trans, A1, Joels on Joy, A&A, Coan all make versions of them .
[Re: 340Cuda]
#3155622
06/30/23 04:15 PM
06/30/23 04:15 PM
Posts: 2,928 Canada
RobR
Canada
[Re: RobR]
#3155629
06/30/23 04:55 PM
06/30/23 04:55 PM
dvw
MI, usa
Called Dave yesterday with a few questions. Nice guy and easy to get info from. Personally with Joel, smartest trans guy I've ever met in person. Doug
