Page 5 of 6 1 2 3 4 5 6
Re: 700 hp default combo? [Re: BDS871Cuda] #31518
12/08/06 02:53 PM
12/08/06 02:53 PM
AndyF Offline OP
AndyF  Offline OP
I haven't gotten my hands on the new Victors yet but I do know that if I took my existing motor that makes 740 hp and put a Victor intake on it with a 4150 carb that it would lose between 80 and 100 hp. I know the 4150 carb loses 50 hp even on the 440-2 intake since I just finished the set of tests. And I know that the Victor manifold with the small runners loses another 30-40 hp over the 440-2 since I've done those tests before.
So I'm thinking that unless the Victor heads are magically wonderful, those std port parts will give up a ton of power to the Dominator+max wedge port combo.
Re: 700 hp default combo? [Re: AndyF] #31519
12/08/06 03:54 PM
12/08/06 03:54 PM
San Diego
StrokedDart Offline
StrokedDart  Offline
San Diego
I know what I want for Christmas now.
1968 Dart
Re: 700 hp default combo? [Re: StrokedDart] #31520
12/08/06 04:02 PM
12/08/06 04:02 PM
Maryland
O
OriginalRT Offline
OriginalRT  Offline
O
Maryland
WOW ... and to think I was on the fence weather or not I wanted Jeff to open my Eddys to MW port or not. I was so in love with my WEIAND six pack set up but last minute ... I told him to open the ports up and I'd use another intake. I'm glad I did now
Thanks Andy once again for hookin us up with what works and how
Re: 700 hp default combo? [Re: OriginalRT] #31521
12/08/06 04:12 PM
12/08/06 04:12 PM
AndyF Offline OP
AndyF  Offline OP
Your results might vary. Remember, I'm working with a 505 inch motor that is 13.5 compression, open headers, big cam, etc.
But yeah, the 950HP carb made 690 hp and the 1050 Dominator went 740 hp. Same motor, same dyno, same day, same intake, etc. The 950HP is a small venturi 4150 carb so maybe a 850DP would make a little more power.
Re: 700 hp default combo? [Re: AndyF] #31522
12/08/06 04:22 PM
12/08/06 04:22 PM
Maryland
O
OriginalRT Offline
OriginalRT  Offline
O
Maryland
I currently have a Pro-Systems 950 and the Indy2 intake. I think I'm gonna skip the dominator though ... I want to get that X-box when I step up
Re: 700 hp default combo? [Re: OriginalRT] #31523
12/08/06 06:36 PM
12/08/06 06:36 PM
AndyF Offline OP
AndyF  Offline OP
The 440-2 with a Dominator made more power (and costs a lot less) than the Indy X ram on my motor. Fast68 did some dyno testing where the X ram made more power than a 440-2 (or 440-3) intake. So I'd say the two are close in power but the single 4bbl will cost a lot less and be easier to dial in.
However, the x ram with dual carbs does have a big wow factor so that is cool.
Re: 700 hp default combo? [Re: AndyF] #31524
12/08/06 11:31 PM
12/08/06 11:31 PM
W
Wedge Offline
Wedge  Offline
W
I see that we don't have a 700 hp baseline in the archives so I figured I'd take a stab at it. I'm sure it can be done many different ways but this seems to be a fairly cost effective method:
RB block 4.350 bore
4.250 crank with 2.200 pins
6.800 Chevy rods
12.5 CR. (Diamond flat top shelf piston at zero deck)
Indy EZ heads with CNC porting by Modern Cylinder Head
Indy 440-3 intake or 440-2 with 4500 adapter
1050 Dominator carb
Flat tappet cam about the size of a MP .620
2 inch headers
Torque peak should be around 5200 rpm with power peak around 6200 rpm.
Great Thread.
Would you recommend any special block prep(hard block, aftermarket caps, top end oil restrictions)?
Re: 700 hp default combo? [Re: AndyF] #31525
12/10/06 01:30 AM
12/10/06 01:30 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i'll have to try that test on the 446 i'll be testing here shortly.
i dont expect to see anywhere near that much difference on the smaller motor.
when you ran the 440-2, did you use a spacer under the carb??
if not, then you're really comparing the big carb, with a 2" spacer, vs the small carb with no spacer.
some data:
my 451 used 960cfm at 7500rpm, and my buddies 557 used 1050cfm at 7000...same carb, same manifold.
my motor peaked at 7300, his peaked at 6400.
at peak power, my motor used 953cfm, his used 1003cfm.
the bsac at peak hp, my motor = 6.23, his motor = 6.34
the bsac at peak tq, my motor = 5.61, his motor = 5.52
i did do the carb test on a 600hp 446 a year or so ago with std port SR heads and a Victor intake:
Victor with 2" Super Sucker and HP950 carb =
544.4 ft/lbs @ 5300, 608.0hp @ 6500
Victor with Moroso 2" adapter and 1050 carb =
546.0 ft/lbs @ 5100, 613.9hp @ 6500
Victor with Moroso 2" adapter and Pro-Systems 1080 carb =
549.6 ft/lbs @ 5200, 615.2hp @ 6500
Re: 700 hp default combo? [Re: fast68plymouth] #31526
12/10/06 02:16 AM
12/10/06 02:16 AM
AndyF Offline OP
AndyF  Offline OP
I used a 2 inch tapered spacer under the 950 and the 2 inch adapter under the 1050. They both were blended into the manifold so I think it was a fair comparison. I didn't expect the 950HP carb to give up 50 hp but it did on these dyno pulls.
Re: 700 hp default combo? [Re: fast68plymouth] #31527
12/10/06 10:30 AM
12/10/06 10:30 AM
NC
440Jim Offline
440Jim  Offline
NC
On a smaller CID motor with smaller heads, intake, and cam, I agree. But I track tested my 511 with my 950hp carb and my 1150 Dominator and it was 0.2 seconds different. 1050 adapter with the 440-2 (modified), and no spacer with the 950hp (trying to slow it down for the 10.00 class). That is about 45 horsepower at my ET/weight.
Then again my buddy's 499 CID with SR heads, 400-2 intake, and smaller headers saw very little improvement going from my 950hp with 1" spacer to his 1050 Pro Systems Dominator with the adapter. And it wasn't the 1050 carb's fault, as we swapped my 1150 carb onto his car and it ran the same. Something else is the limiting factor on his combo.
Re: 700 hp default combo? [Re: 440Jim] #31528
12/10/06 11:02 AM
12/10/06 11:02 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
This is a great thread! I have a set of MW ported SR's and a ported IC 12 intake. I have a .640 roller on a 110 lsa. From reading this stuff I would think that a 10:1 528 would get me there very easily on pump gas!
I just need to fork out the dough for the TTI headers so that everything will fit nicely in the Bird.
Re: 700 hp default combo? [Re: BradH] #31529
12/10/06 01:24 PM
12/10/06 01:24 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
470"... 10.9:1 compression, pump gas, Box Stock Victor heads and manifold with a .670 lift solid roller with [Email]270@.050.[/Email] It made 711 horsepower with a 1000 cfm 4150 carb.
On whose dyno? Sounds to me.
Well, I just had my buddy read these posts about his combo and he laughed at all the doubt, but he did correct me at one thing and that was the carb. He only had two carbs, one 950 and the other a dominator. The Dominator is what made the 711 hp and the 950cfm 4150 made 694 hp. He also dropped on a set of stock performer RPMs as a comparison and the engine only made 620 hp. This same engine had a set of ported RPMs on it in the past and it made I believe 670 hp. But I guess all these numbers are all fabricated unless you actually witness the engine on a reputable dyno. Have fun tearing up these numbers to.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: 700 hp default combo? [Re: PUNK] #31530
12/10/06 10:29 PM
12/10/06 10:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have no doubt that his engine made the numbers you stated on that particular dyno. I also have serious doubts that those same combinations you described would make those #s on the dyno I've used for my last two dyno sessions.
This is just one more good example of why you can't compare the results of different dynos or different flow benches.
Re: 700 hp default combo? [Re: PUNK] #31531
05/12/07 06:01 PM
05/12/07 06:01 PM
P
PUNK Offline
PUNK  Offline
P
Well, Im sure everyones read the Victor engine build article by now showing the possibilities of these heads. They are killer heads. Now only if they were more easily available.
Re: 700 hp default combo? [Re: PUNK] #31532
05/12/07 10:01 PM
05/12/07 10:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Are we saying an OOTB Victor will go 700hp with a 906 port window? Find that tough to believe from what I've seen of it (it just looks a little small for that HP) but I suspect it might with enough CR and a big enough cam opened early and with a tight center. I remember reading somewhere the Vic is limited to a 2.19" intake valve, is that right?
Fast's new test of a 505 is right down the pipe of how I'd do it for an automatic equipped B or E body, but I'd be curious to see an SR withan equal Intake and a better Exhaust port....the EZ's achilles heel is the low exhaust port but enough CR and a longer duration can offset a 'weak' port. I suspect an SR as described might make another 20 or so all else being equal. I'd love to see what the Chapman 285 (flows at .500 what the EZ does at .600 and another +30 at .6) would do on that combo.
A dominator will typically out et a comparable 4150 down the track (assumin enough gear and stall) because there will be less of a pressure drop across the venturis at WOT which normally equates to more torque being produced down the track. That said, unless you have enough stall to take WOT off the line, your results may vary.
I'd love to see a 700HP 'real street' combo...i.e, one that is truly docile enough for street driving with these conditions/stipulations....The motor's gotta fit under a Stock B or E hood (so the car looks outwardly visually "correct"), run a 3500 max stall and on pump gas and put a 3800 pound car well into the 10's with no more than a 3.91 gear.
WIZE
In Car:
Re: 700 hp default combo? [Re: AndyF] #31533
12/07/10 11:41 PM
12/07/10 11:41 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Been a while , how bout a bump, and add Firecore50 Ignition Wires.. !!
Good thread.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 700 hp default combo? [Re: sunroofgtx] #31534
12/08/10 12:09 AM
12/08/10 12:09 AM
BradH Offline
BradH  Offline
Uhhhh... 3 years and 7 months since this was last updated before today???
Things a little slow around the Wire Factory, Rick?
Re: 700 hp default combo? [Re: BradH] #31535
12/08/10 02:48 AM
12/08/10 02:48 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'll take donations to dyno the 500" stroked 400
I'd be happy if it makes 700 HP.
Basic 500" stroker low deck short block, 4.375" bore, 4.150" stroke, 6.76" Rods, KB/ICON forged flat tops. With The Victor MW heads and cometic 0.040" gasket, about 12.4:1 compression.
Added BCR aluminum mains with girdle, Milodon oil pan, internal 1/2" pickup, ATI dampner, Hi-Volume oil pump.
Heads are the max wedge Edelbrock Victors, currently only mildly ported, with multi-angle valve job and alot of pushrod clearancing. I tried to get 2.00" install height on the valve springs, but ran out of clearance between the retainer and rocker arm. If you plan to run these heads with over 0.700" lift, I would get the heads bare, and use valves with 0.100" longer valve stems. I ended up milling off the rocker stands anyhow. Used T&D 1.6:1 rocker arms. I think these have an intake offset of 0.700". Custom pushrods with the intake 0.025" longer than the exhaust because of the rocker offset. I used the PAC-1325 valve springs, crower Ti retainers that should handle a pretty agressive roller cam. Probably overkill for my mild cam, but with a bigger cam, I would have to deepen the piston valve reliefs. The cam is a custom Comp solid roller with the HXL lobes, 264/264 @ 0.050" duration, 0.714"/0.714" lift, 112 LSA (it in a heavy street/strip car) installed at 108 cl (I may retard it, has plenty of torque.)
Intake is an Indy 400-2 4150 intake so I could re-use my Holley 1,000 cfm carb and also so it would fit under the cars hood (factory '72 Charger Power bulge hood.) I am also re-using my Hooker 2" super comp headers going into a 3" dual TTI exhaust system with crossover and the super turbo mufflers.
Re: 700 hp default combo? [Re: 451Mopar] #31536
12/08/10 10:07 AM
12/08/10 10:07 AM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
In the early 90's we ran this 499ci in our 69' Barracuda....
4.375 x 4.150 RB
6.76 BME rods
11.8 static (IIRC)
620 solid
906 heads (ported by my brother)
M1 intake (gasket match)
1050 (9375)
727 footbrake
9in J
SS springs w/inboard kit
4.56
At 3380# it ran 10.03 @135+ first time out. We only raced that combination once because we changed it over to 440-1s and a roller.....but, it was street driven constantly.
I would be surprised if even an Edelbrock RPM head, ported correctly, with the proper roller cam, couldn't approach 700hp at 500ci in a well thought out build.
Re: 700 hp default combo? [Re: sunroofgtx] #31537
12/08/10 11:22 AM
12/08/10 11:22 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Good thread.
This one made 705 (720 with a dominator) on 93UL pump swill with a set of 8.5mm Firecores
https://board.moparts.org/ubbthreads/show...e=0#Post5622009
Ron
