Re: Indy 440-SR's on a 383?
[Re: Silver68RT]
#3151081
06/13/23 08:04 AM
06/13/23 08:04 AM
Posts: 10,022 MN
JERICOGTX
MN
The SR's will work well on a 383, as long as they still have 2.19 intake valves. I don't think the bore of a 383 can take the 2.250 intake valves?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3151091
06/13/23 08:42 AM
06/13/23 08:42 AM
Posts: 87 Michigan
Silver68RT
The SR's will work well on a 383, as long as they still have 2.19 intake valves. I don't think the bore of a 383 can take the 2.250 intake valves? Looks like they're still 2.19 as close as I can tell with my calipers. Thanks for the tip, I'll have to make sure they clear the bore.
[Re: BigBlockGTS]
#3151092
06/13/23 08:45 AM
06/13/23 08:45 AM
Posts: 10,022 MN
JERICOGTX
MN
Not a pro but I have always seen warnings on not using a 2.19 intake on a 383. I think Trickflow heads say that their heads won't work on 383s for this reason. That said, I have never heard of anyone actually having a problem and there appear to be a few out there. Not sure if it is only on a stock bore and .030 or .060 over does the trick? I'd be curious to know as I have a 383 that needs good heads. A long lost member of this board ran a 431ci combo (383 block w/440 crank) for many years with SR heads. Combo ran 10's in a 70 Road Runner for years.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3151398
06/14/23 05:15 AM
06/14/23 05:15 AM
Posts: 2,917 A shed in England
Tig
A shed in England
Indy used to make a 383-13 head, designed for the smaller bore but I can't find any specs on them. I know a few that have run the -1 heads on B blocks but not sure on the bore size they used. I'm not much help but I'd maybe ring or email Indy Cylinder Head.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3151404
06/14/23 07:24 AM
06/14/23 07:24 AM
Posts: 87 Michigan
Silver68RT
Indy used to make a 383-13 head, designed for the smaller bore but I can't find any specs on them. I know a few that have run the -1 heads on B blocks but not sure on the bore size they used. I'm not much help but I'd maybe ring or email Indy Cylinder Head. Interesting, never heard of those. I think I'm going to save the 440-SR's for my 400 or one of the 440's I've got, but with Best Machine closing I don't even know where to take those now. The 440-SR's I bought came with TTI headers for an RB in a B/E-body so I probably would have had to get different ones for the B-block, and they definitely aren't cheap. So, I guess I'm looking for some Edelbrock RPM's or some 440 Source Stealth heads, something with a 2.14 intake. I was considering the Trick Flow 240's, but they say right on the description that the minimum bore is 4.32". I hadn't noticed that before.
[Re: Silver68RT]
#3151412
06/14/23 08:11 AM
06/14/23 08:11 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
A low deck block w/ the raised port SR or -1 heads can use a regular header for a RB block.
[Re: an8sec70cuda]
#3151414
06/14/23 08:35 AM
06/14/23 08:35 AM
Posts: 87 Michigan
Silver68RT
A low deck block w/ the raised port SR or -1 heads can use a regular header for a RB block. OK, that changes the math quite a bit if I don't have to spend a grand on new headers. I've got another set of regular RB ceramic coated headers already.
[Re: an8sec70cuda]
#3151420
06/14/23 09:20 AM
06/14/23 09:20 AM
Posts: 10,022 MN
JERICOGTX
MN
A low deck block w/ the raised port SR or -1 heads can use a regular header for a RB block. Correct. I ran Hooker 5209’s on my 499 forever.
69 GTX
68 Road Runner
[Re: gregsdart]
#3151444
06/14/23 11:08 AM
06/14/23 11:08 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
max wedge motors i believe had a chamfer ground in where the intake valve came close? Just make sure no relief is ground far enough down the bore to be close to the top ring! I thought it was on the exh side ?
[Re: Silver68RT]
#3151517
06/14/23 03:06 PM
06/14/23 03:06 PM
Posts: 31,029 Oregon
AndyF
So what about the intake manifold? I found a 383 intake shootout on Hot Rod. Looks like the TM6 did pretty well at 510 hp on their 383 with CNC ported Edelbrock RPM's. The Weiand tunnel ram was really good at 540 hp, but it looks like those are hard to find. They went with a lot more cam too. https://www.motortrend.com/how-to/hrdp-0801-mopar-intake-manifolds/ Best intake is the Trick Flow. I assume your SR heads are standard port size?
[Re: AndyF]
#3151604
06/14/23 07:14 PM
06/14/23 07:14 PM
Posts: 87 Michigan
Silver68RT
So what about the intake manifold? I found a 383 intake shootout on Hot Rod. Looks like the TM6 did pretty well at 510 hp on their 383 with CNC ported Edelbrock RPM's. The Weiand tunnel ram was really good at 540 hp, but it looks like those are hard to find. They went with a lot more cam too. https://www.motortrend.com/how-to/hrdp-0801-mopar-intake-manifolds/ Best intake is the Trick Flow. I assume your SR heads are standard port size? Yes, standard port size. I was told the previous owner used them with a Six Pack setup, but then put it back to stock. The guy I bought the short block from went with a Trick Flow intake on his 512 stroker, looked like a nice piece.
[Re: Silver68RT]
#3151912
06/15/23 11:01 PM
06/15/23 11:01 PM
Posts: 553 Kentucky
clovis
Kentucky
I did a lot of intake and carb testing last year with a 383/906 heads. I have run the Victor 383, RPM, TM6, and M1 (4500). I had good results with RPM but would say that it really likes a 2” merge spacer. The TM6 actually ran just a tad better than the RPM again 2” spacer. The last intake I tried was the M1 4500, I spun a rod on a test hit near the house so it never went down the track but I will likely start there on the new motor. Don’t be afraid to try a 4500 carb either. I have a torker, Street Dominator, and a Weiand tunnel ram left to experiment with. I’m sure the tunnel ram will make an appearance at some point.
As far as cam I would give Dwayne Porter a call and tell him what you’re going to do with the car and he should be able to help. My cam is a solid flat tappet 250@.050 and with a home ported 906 I’ve gone a best of 11.17 at 3400lbs.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
