Indy 440-SR's on a 383? #3151076
06/13/23 07:17 AM
06/13/23 07:17 AM
Silver68RT Offline OP
I just picked up a fresh 383 short block from a guy who swapped it out for a 512 stroker. It has a Crane hydraulic roller cam 230/236 @ .050, 0.528 / 0.539, 112 LSA, says 3,000 to 6.500 rpm. He was running Edelbrock RPM's on it, but kept them and had them ported for the stroker. I have a set of Indy 440-SR's that I bought years ago, and I was wondering if those would work well with that cam on a 383? He threw in some 516 iron heads, but I think they'd need work. Also wondering what intake to use. It came with an Edelbrock TM6 single plane. Looking for a nice street/strip combination, and wondering what you guys think, or if you have some suggestions for different heads to use.
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151081
06/13/23 08:04 AM
06/13/23 08:04 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The SR's will work well on a 383, as long as they still have 2.19 intake valves. I don't think the bore of a 383 can take the 2.250 intake valves?
69 GTX 68 Road Runner
Re: Indy 440-SR's on a 383? [Re: JERICOGTX] #3151089
06/13/23 08:38 AM
06/13/23 08:38 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Not a pro but I have always seen warnings on not using a 2.19 intake on a 383. I think Trickflow heads say that their heads won't work on 383s for this reason. That said, I have never heard of anyone actually having a problem and there appear to be a few out there. Not sure if it is only on a stock bore and .030 or .060 over does the trick? I'd be curious to know as I have a 383 that needs good heads.
Re: Indy 440-SR's on a 383? [Re: JERICOGTX] #3151091
06/13/23 08:42 AM
06/13/23 08:42 AM
Looks like they're still 2.19 as close as I can tell with my calipers. Thanks for the tip, I'll have to make sure they clear the bore.
Re: Indy 440-SR's on a 383? [Re: BigBlockGTS] #3151092
06/13/23 08:45 AM
06/13/23 08:45 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
A long lost member of this board ran a 431ci combo (383 block w/440 crank) for many years with SR heads. Combo ran 10's in a 70 Road Runner for years.
Re: Indy 440-SR's on a 383? [Re: JERICOGTX] #3151301
06/13/23 06:56 PM
06/13/23 06:56 PM
gregsdart Offline
gregsdart  Offline
max wedge motors i believe had a chamfer geound in where the intake valve came close? Just make sure no relief is ground far enough down the bore to be close to the top ring!
Re: Indy 440-SR's on a 383? [Re: gregsdart] #3151308
06/13/23 07:01 PM
06/13/23 07:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A stock bore 383 .is 4.250" vs 440 4.320". That put's the valve .035" closer if the 383 is stock bore. At worst a slight notch.
Doug
Re: Indy 440-SR's on a 383? [Re: gregsdart] #3151309
06/13/23 07:01 PM
06/13/23 07:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
At least .100 above the top ring. For chamfer bottom.
Re: Indy 440-SR's on a 383? [Re: JERICOGTX] #3151398
06/14/23 05:15 AM
06/14/23 05:15 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Indy used to make a 383-13 head, designed for the smaller bore but I can't find any specs on them. I know a few that have run the -1 heads on B blocks but not sure on the bore size they used. I'm not much help but I'd maybe ring or email Indy Cylinder Head.
Re: Indy 440-SR's on a 383? [Re: Tig] #3151404
06/14/23 07:24 AM
06/14/23 07:24 AM
Interesting, never heard of those. I think I'm going to save the 440-SR's for my 400 or one of the 440's I've got, but with Best Machine closing I don't even know where to take those now. The 440-SR's I bought came with TTI headers for an RB in a B/E-body so I probably would have had to get different ones for the B-block, and they definitely aren't cheap.
So, I guess I'm looking for some Edelbrock RPM's or some 440 Source Stealth heads, something with a 2.14 intake. I was considering the Trick Flow 240's, but they say right on the description that the minimum bore is 4.32". I hadn't noticed that before.
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151405
06/14/23 07:44 AM
06/14/23 07:44 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The indy catalog says 383 cubes for the sr.
I am a sr believer.
2.19 + 1.81 = 4.00 there ain't a quarter inch between the valves. plenty of room.
The cam sucks
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151412
06/14/23 08:11 AM
06/14/23 08:11 AM
an8sec70cuda Offline
A low deck block w/ the raised port SR or -1 heads can use a regular header for a RB block.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy 440-SR's on a 383? [Re: an8sec70cuda] #3151414
06/14/23 08:35 AM
06/14/23 08:35 AM
OK, that changes the math quite a bit if I don't have to spend a grand on new headers. I've got another set of regular RB ceramic coated headers already.
Re: Indy 440-SR's on a 383? [Re: an8sec70cuda] #3151420
06/14/23 09:20 AM
06/14/23 09:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Correct. I ran Hooker 5209’s on my 499 forever.
Re: Indy 440-SR's on a 383? [Re: gregsdart] #3151444
06/14/23 11:08 AM
06/14/23 11:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by gregsdart
max wedge motors i believe had a chamfer ground in where the intake valve came close? Just make sure no relief is ground far enough down the bore to be close to the top ring!
I thought it was on the exh side ?
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151460
06/14/23 12:00 PM
06/14/23 12:00 PM
So what about the intake manifold? I found a 383 intake shootout on Hot Rod. Looks like the TM6 did pretty well at 510 hp on their 383 with CNC ported Edelbrock RPM's. The Weiand tunnel ram was really good at 540 hp, but it looks like those are hard to find. They went with a lot more cam too.
https://www.motortrend.com/how-to/hrdp-0801-mopar-intake-manifolds/
Re: Indy 440-SR's on a 383? [Re: JohnRR] #3151494
06/14/23 02:08 PM
06/14/23 02:08 PM
You are correct up bow grin shruggy
I've notch more than one 426W and 383 blocks for the 1.81 (maybe, CRS now blush) and 1.88 bigger exhaust valves wrench up
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151517
06/14/23 03:06 PM
06/14/23 03:06 PM
AndyF Offline
AndyF  Offline
Best intake is the Trick Flow. I assume your SR heads are standard port size?
Re: Indy 440-SR's on a 383? [Re: AndyF] #3151604
06/14/23 07:14 PM
06/14/23 07:14 PM
Yes, standard port size. I was told the previous owner used them with a Six Pack setup, but then put it back to stock.
The guy I bought the short block from went with a Trick Flow intake on his 512 stroker, looked like a nice piece.
Re: Indy 440-SR's on a 383? [Re: Silver68RT] #3151912
06/15/23 11:01 PM
06/15/23 11:01 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I did a lot of intake and carb testing last year with a 383/906 heads. I have run the Victor 383, RPM, TM6, and M1 (4500). I had good results with RPM but would say that it really likes a 2” merge spacer. The TM6 actually ran just a tad better than the RPM again 2” spacer. The last intake I tried was the M1 4500, I spun a rod on a test hit near the house so it never went down the track but I will likely start there on the new motor. Don’t be afraid to try a 4500 carb either. I have a torker, Street Dominator, and a Weiand tunnel ram left to experiment with. I’m sure the tunnel ram will make an appearance at some point.
As far as cam I would give Dwayne Porter a call and tell him what you’re going to do with the car and he should be able to help. My cam is a solid flat tappet 250@.050 and with a home ported 906 I’ve gone a best of 11.17 at 3400lbs.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
