Are Cone-type Suregrips That Bad? #315090
05/11/09 05:42 PM
05/11/09 05:42 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I know you can't rebuild them in the conventional sense. But how does their strength and actual traction capability compare to a clutch-type suregrip?
There is a 489 case, 3.91, cone-type suregrip available locally for $300. If I gamble and it works, it could save me $700 or so over getting a rehabbed center section.
This will be for a 12 second street/strip car. Thanks!
Re: Are Cone-type Suregrips That Bad? [Re: 67Satty] #315091
05/11/09 05:49 PM
05/11/09 05:49 PM
MNobody Offline
MNobody  Offline
Mine leaves identical track's right to left.
Re: Are Cone-type Suregrips That Bad? [Re: MNobody] #315092
05/11/09 06:03 PM
05/11/09 06:03 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If you buy it take the sure grip apart and machine and shim the cones if need be.
Re: Are Cone-type Suregrips That Bad? [Re: 69Cuda340S] #315093
05/11/09 06:08 PM
05/11/09 06:08 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I like to burn rubber. Alot. As in 100 ft or more through several gears. Out of all of the Sure-Grips I have had, only one was a cone style and it seemed to "fishtail". Maybe it was worn out. I swapped it for a clutch style with the same ratio and now it burns rubber straight as an arrow. That's all I know.
Stan
Re: Are Cone-type Suregrips That Bad? [Re: HemiStan] #315094
05/11/09 06:13 PM
05/11/09 06:13 PM
Az
Crizila Offline
Crizila  Offline
Az
I run one in my 9 1/4. No problems so far. Third season with it.
Fastest 300
Re: Are Cone-type Suregrips That Bad? [Re: Crizila] #315095
05/11/09 07:02 PM
05/11/09 07:02 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Maybe not that bad, but after all these years of use or abuse, they could it be some damaged, so not a guarantee of good working conditions.
Being the clutch kind are easier and cheaper rebuildable, kist are everywhere, and able to make it at home, thats an advantage. Cone kind will need to me machined as stated, not too cheap to make that.
Re: Are Cone-type Suregrips That Bad? [Re: NachoRT74] #315096
05/11/09 07:14 PM
05/11/09 07:14 PM
MNobody Offline
MNobody  Offline
Not sure what it cost to rebuild the clutch style but gringing off a couple gears and adding washers can't be that expensive.
Re: Are Cone-type Suregrips That Bad? [Re: NachoRT74] #315097
05/11/09 07:14 PM
05/11/09 07:14 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
I had my cones machined for about $40. Also involves putting a shim washer between the cone and gear that's the same thickness as the amount machined. Worked great for about 50K miles. You can do this maybe twice, before they are totally dead. There are two websites about doing this out there, which you can probably find through Google.
Re: Are Cone-type Suregrips That Bad? [Re: HemiStan] #315098
05/11/09 07:16 PM
05/11/09 07:16 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
Stan
Yes, on the street where there is good traction, (versus the test n' tune track, where they really don't give a flying flip whether you get good traction, and the kidz dump their A/C fluids) , my "sure grip " fishtails , too. Good luck finding a clutch unit, though. Limited availibility, no ?
Re: Are Cone-type Suregrips That Bad? [Re: NachoRT74] #315099
05/11/09 07:36 PM
05/11/09 07:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually, I would have gone to a clutch type ( for the rebuildability thing ), but they are not available for the 9 1/4 diff. Per Auburn gear, the check to see if your cone unit is still serviceable is easy ( applies to a 9 1/4 - don't know about others): Jack one tire off the ground. Put a torque wrench on a lug nut on that wheel ( radially out from the wheel center ). Break-away torque for a new unit should be 70 lbs or better. They claim the unit is serviceable down to 20 lbs. Below that, replace. They also suggest 80-90 gear oil only. No synthetic. An additive os ok if you have bad chatter on turns.
Fastest 300
Re: Are Cone-type Suregrips That Bad? [Re: IronWolf] #315100
05/11/09 07:37 PM
05/11/09 07:37 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I have had VERY good luck with them.
The 741 2.76 SG I have in my 62 Belvedere right now came out of a 74 Monaco with 170k miles on it. It has been in there since the middle '90's, has run as quick as 12.30 and as fast as 5200 in high gear !
It is as tight as a drum !! ..
Re: Are Cone-type Suregrips That Bad? [Re: 67Satty] #315101
05/11/09 07:49 PM
05/11/09 07:49 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
i have had bad experience with those ones. I have never torn up the clutch type but have torn out 3 or the cone type.
1.was in a stock 318 barracuda. the pin in the middle came out and tore up the ring and pinion gears.
2.was in a 360 dart same thing happened
3. was in another 318 car.
they were all 4 speeds and so that was hard on them but only the 360 car had very much power, high 12's in quarter. i will never run another one of those units. trashed 3 sets of gears with them. i have never broken the clutch type and i have one behind my 440 dart.
Re: Are Cone-type Suregrips That Bad? [Re: dirt] #315102
05/11/09 08:14 PM
05/11/09 08:14 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Are Cone-type Suregrips That Bad? [Re: Crizila] #315103
05/11/09 08:20 PM
05/11/09 08:20 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
They have their place but the bad part is when they do slip it's metal on metal which ends up in the oil running through the bearings,seals, ring and pinion
Re: Are Cone-type Suregrips That Bad? [Re: 500ciDuster] #315104
05/11/09 09:14 PM
05/11/09 09:14 PM
Az
Crizila Offline
Crizila  Offline
Az
Actually it's metal to metal every time you turn a corner. I've run the same center section with three different sets of gears over the last 2 years. Haven't noticed any gear / bearing wear or metal in the oil. Now that I've said that, it will probably self destruck the next time I go out!
Fastest 300
Re: Are Cone-type Suregrips That Bad? [Re: Crizila] #315105
05/11/09 09:23 PM
05/11/09 09:23 PM
scratchnfotraction Offline
they ar ok..just not good on longevity
as the cone wears it eats into the case and puts metal shving in the oil
most I have seen used have not had very good service on the oil change and the bearing are pitted up
but when in good working order they are just as good as a clutch one IMO
just wont last as long with out preventive maintanace and oil changes
look it over good so it not 700$ after the 300+ $ used
I have had one redone,its tight as a .....
well it chatters the tire on turns so its a grabin good lets say
runwhatyabrung
Re: Are Cone-type Suregrips That Bad? [Re: Crizila] #315106
05/11/09 10:15 PM
05/11/09 10:15 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Clutch types are available forthe 9.25 all the suregrip truck axles are a clutch type LSD. I know because I took one apart, and sold the empty diff with side gears to a kid who was going to rebuild it and put it in his Dakota--I pulled it out because it needed rebuilt and i wanted to go with a detroit true trac
now, if you're talking about an old 9.25 from a car, I don't know if they make one for that specific application (did the spline count change on them?) if so, you could buy one meant for a truck axle, and just get new axles for your older diff
**Photobucket sucks**
Re: Are Cone-type Suregrips That Bad? [Re: 67Satty] #315107
05/11/09 10:23 PM
05/11/09 10:23 PM
Ca Registered: Mar-2001
hemiallen Offline
hemiallen  Offline
Or you could buy as good clutch 741 pig in the classified, Northern Cal, shipping may not be that bad.
741'S are stonger than your 12 second car needs.....
It's a 3.91 set, looks new and runs like new.
Allen
'05 Quad cab hemi truck- Flame red- magnaflow exhaust 70-440 cuda- 74-360-4v Challenger- new driver car EX vehicles: 66 charger Drag car- 10.80 at 123 mph 57 imperial 392 Hemi 1960 Sanger V drive- mondello-built 392 hemi
Re: Are Cone-type Suregrips That Bad? [Re: 70Cuda383] #315108
05/12/09 08:20 AM
05/12/09 08:20 AM
Az
Crizila Offline
Crizila  Offline
Az
Good info - thanks. I didn't know that. The 9 1/4 I have came with the car ( 79 300 - Cordoba ). It was originally open and I added the Auburn center section - cone clutch. I'm not having any problems with it so far. I'll probably stick with it for now.
Fastest 300
Re: Are Cone-type Suregrips That Bad? [Re: dirt] #315109
05/12/09 08:53 AM
05/12/09 08:53 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
The cone sure-grips only have 2 spider gears and they gall onto the center pin forcing it to break the locating pin and making the cross shaft spin in the case wallowing out the case holes. I'd say this is more of an issue than the "self destructing" complaint.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
