Re: Are Cone-type Suregrips That Bad?
[Re: HemiStan]
#315094
05/11/09 06:13 PM
05/11/09 06:13 PM
Posts: 7,506 Az
Crizila
Az
I run one in my 9 1/4. No problems so far. Third season with it.
Fastest 300
[Re: Crizila]
#315095
05/11/09 07:02 PM
05/11/09 07:02 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Maybe not that bad, but after all these years of use or abuse, they could it be some damaged, so not a guarantee of good working conditions.
Being the clutch kind are easier and cheaper rebuildable, kist are everywhere, and able to make it at home, thats an advantage. Cone kind will need to me machined as stated, not too cheap to make that.
[Re: NachoRT74]
#315096
05/11/09 07:14 PM
05/11/09 07:14 PM
Posts: 4,884 Michigan
MNobody
Not sure what it cost to rebuild the clutch style but gringing off a couple gears and adding washers can't be that expensive.
[Re: HemiStan]
#315098
05/11/09 07:16 PM
05/11/09 07:16 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
I like to burn rubber. Alot. As in 100 ft or more through several gears. Out of all of the Sure-Grips I have had, only one was a cone style and it seemed to "fishtail". Maybe it was worn out. I swapped it for a clutch style with the same ratio and now it burns rubber straight as an arrow. That's all I know.
Stan
Yes, on the street where there is good traction, (versus the test n' tune track, where they really don't give a flying flip whether you get good traction, and the kidz dump their A/C fluids) , my "sure grip " fishtails , too. Good luck finding a clutch unit, though. Limited availibility, no ?
[Re: NachoRT74]
#315099
05/11/09 07:36 PM
05/11/09 07:36 PM
Posts: 7,506 Az
Crizila
Az
Actually, I would have gone to a clutch type ( for the rebuildability thing ), but they are not available for the 9 1/4 diff. Per Auburn gear, the check to see if your cone unit is still serviceable is easy ( applies to a 9 1/4 - don't know about others): Jack one tire off the ground. Put a torque wrench on a lug nut on that wheel ( radially out from the wheel center ). Break-away torque for a new unit should be 70 lbs or better. They claim the unit is serviceable down to 20 lbs. Below that, replace. They also suggest 80-90 gear oil only. No synthetic. An additive os ok if you have bad chatter on turns.
Fastest 300
[Re: IronWolf]
#315100
05/11/09 07:37 PM
05/11/09 07:37 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
I have had VERY good luck with them. The 741 2.76 SG I have in my 62 Belvedere right now came out of a 74 Monaco with 170k miles on it. It has been in there since the middle '90's, has run as quick as 12.30 and as fast as 5200 in high gear ! It is as tight as a drum !! ..
[Re: Crizila]
#315105
05/11/09 09:23 PM
05/11/09 09:23 PM
Posts: 15,487 Florida
scratchnfotraction
they ar ok..just not good on longevity as the cone wears it eats into the case and puts metal shving in the oil most I have seen used have not had very good service on the oil change and the bearing are pitted up but when in good working order they are just as good as a clutch one IMO just wont last as long with out preventive maintanace and oil changes look it over good so it not 700$ after the 300+ $ used I have had one redone,its tight as a ..... well it chatters the tire on turns so its a grabin good lets say runwhatyabrung
[Re: Crizila]
#315106
05/11/09 10:15 PM
05/11/09 10:15 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Clutch types are available forthe 9.25 all the suregrip truck axles are a clutch type LSD. I know because I took one apart, and sold the empty diff with side gears to a kid who was going to rebuild it and put it in his Dakota--I pulled it out because it needed rebuilt and i wanted to go with a detroit true trac
now, if you're talking about an old 9.25 from a car, I don't know if they make one for that specific application (did the spline count change on them?) if so, you could buy one meant for a truck axle, and just get new axles for your older diff
**Photobucket sucks**
[Re: 67Satty]
#315107
05/11/09 10:23 PM
05/11/09 10:23 PM
Posts: 2,623 Ca Registered: Mar-2001
hemiallen
Or you could buy as good clutch 741 pig in the classified, Northern Cal, shipping may not be that bad.
741'S are stonger than your 12 second car needs.....
It's a 3.91 set, looks new and runs like new.
Allen
'05 Quad cab hemi truck- Flame red- magnaflow exhaust
70-440 cuda-
74-360-4v Challenger- new driver car
EX vehicles:
66 charger Drag car- 10.80 at 123 mph
57 imperial 392 Hemi
1960 Sanger V drive- mondello-built 392 hemi
[Re: 70Cuda383]
#315108
05/12/09 08:20 AM
05/12/09 08:20 AM
Posts: 7,506 Az
Crizila
Az
Good info - thanks. I didn't know that. The 9 1/4 I have came with the car ( 79 300 - Cordoba ). It was originally open and I added the Auburn center section - cone clutch. I'm not having any problems with it so far. I'll probably stick with it for now.
Fastest 300
