Rear Sway Bar Links #3149062
06/06/23 08:36 AM
06/06/23 08:36 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning,
Installing a rear sway bat into a 73 Challenger. Having trouble finding
the end links. Are they the same as the front?
Thanks!
Re: Rear Sway Bar Links [Re: jim6346] #3149103
06/06/23 12:02 PM
06/06/23 12:02 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
you may not find a listing for that specific application, it's easier to just measure the length needed and order one with the correct ends.
Here's a write up I did when trying for find sway bar links on a 74 Ramcharger with D60/D70 swapped axles and is the same thing I did when I replaced the rear sway bar links on my 70 Coronet R/T which has an old addco sway bar from the late 70's early 80's
https://www.ramchargercentral.com/threads/ramcharger-front-sway-bar-end-link-findings-data.332470/
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Rear Sway Bar Links [Re: jim6346] #3149107
06/06/23 12:15 PM
06/06/23 12:15 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree What sway bar are you using? I’m using front links from like an 1980 El Camino, the links supplied for rear sway bar kit I bought ended up being too short
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Rear Sway Bar Links [Re: metallicareload] #3149115
06/06/23 01:12 PM
06/06/23 01:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Yes what Shanker wrote. When I snapped a rear end link on my '89 Diplomat Police I was never going to find another OEM one. I simply measured length and found an Energy Suspension kit with urethane bushings and replaced both sides. They are very beefy. I used black bushings but they also come in red. VERY inexpensive, and for me somewhat OEM appearing and hidden anyway.
https://www.energysuspensionparts.com/universal-sway-bar-end-links.asp
Facts are stubborn things.
Re: Rear Sway Bar Links [Re: jim6346] #3149118
06/06/23 01:29 PM
06/06/23 01:29 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Depends on how "correct" you want them to look.
Factory ones di not use the center spacer tubes as do the aftermarkets.
Re: Rear Sway Bar Links [Re: PhillyRag] #3149119
06/06/23 01:31 PM
06/06/23 01:31 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Re: Rear Sway Bar Links [Re: larrymopar360] #3149137
06/06/23 02:19 PM
06/06/23 02:19 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Found an article on line, a front sway bar link from a 68-69 B-Body will work.
Got a set from NAPA and worked perfectly!!
Thanks everyone.
