Re: Rear Sway Bar Links
[Re: jim6346]
#3149103
06/06/23 12:02 PM
06/06/23 12:02 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
you may not find a listing for that specific application, it's easier to just measure the length needed and order one with the correct ends. Here's a write up I did when trying for find sway bar links on a 74 Ramcharger with D60/D70 swapped axles and is the same thing I did when I replaced the rear sway bar links on my 70 Coronet R/T which has an old addco sway bar from the late 70's early 80's https://www.ramchargercentral.com/threads/ramcharger-front-sway-bar-end-link-findings-data.332470/
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: PhillyRag]
#3149119
06/06/23 01:31 PM
06/06/23 01:31 PM
Posts: 15,864 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Depends on how "correct" you want them to look. Factory ones di not use the center spacer tubes as do the aftermarkets. VERY inexpensive, and for me somewhat OEM appearing and hidden anyway.
Facts are stubborn things.
