Page 3 of 4 1 2 3 4
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2830691
10/09/20 10:29 AM
10/09/20 10:29 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I bought the 71 NYer from a person I knew and was from my town.
He was an older gentleman who bought the car new and was not one to lie when he said
the engine was as he bought it and ran fine until he had to give up driving because of eyesight problems
The rear baffle as you see does not look like someone cobbled it together, it looks purpose built for that application.
I am of the opinion it is stock.
My 2 cents....Joe
PS the rear baffle is sheet metal, It just looks like a thick piece of steel.
I had to be formed in a die specifically for that part.
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2830798
10/09/20 01:05 PM
10/09/20 01:05 PM
moparx Offline
moparx  Offline
that's how i took the rear baffle to be, sheetmetal with the edges bent down for stiffening.
regardless if factory or not, it's an interesting pan for sure.
beer
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2830865
10/09/20 05:15 PM
10/09/20 05:15 PM
My 2 cents....Joe
I should have been clearer that I have not seen a 187 pan with any baffles in them but all of the ones i have bought and used where from pre 1971 cars shruggy
I have seen both of those baffles used in later year oil pans on the Cordoba motors, but they weren't 187 stamp pans confused
This is another good example to never say never when it comes to things car makers have done on production parts shruggy
OP, do the spot welds on the rear baffle look exactly like the ones on the pump baffle?
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2830870
10/09/20 05:20 PM
10/09/20 05:20 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
No room to beneath the baffle to get a spotweld tip in there, it is brazed.
Joe
Well, so much for my eyes, after cleaning, I can see the spotwelds too!, but smaller
than the sump welds
Re: The best Rear main Seal for a 440? [Re: jlatessa] #2830987
10/09/20 11:23 PM
10/09/20 11:23 PM
The factories quit doing manual welding years ago shruggy
Some one added that on to your pan, probably the same thing on the center part shruggy
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2832157
10/12/20 11:22 PM
10/12/20 11:22 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Fast fish one piece rear seal and a billet retainer with the dual side seals per side..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: The best Rear main Seal for a 440? [Re: HOTMOPR] #2832456
10/13/20 08:39 PM
10/13/20 08:39 PM
Minnesota
TrackPack Offline
TrackPack  Offline
Minnesota
There was an NOS 893 pan for sale on this site, rear baffle brazed in place.
https://board.moparts.org/ubbthread...7/filename/parts%208-24-2020-2%20064.JPG
Re: The best Rear main Seal for a 440? [Re: TrackPack] #2832485
10/13/20 09:47 PM
10/13/20 09:47 PM
I think that is a stock RB,B 1967 to 1969 A body oil pan. Not a stock 1966 to 1972 C body oil pan
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #2832523
10/14/20 12:16 AM
10/14/20 12:16 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: The best Rear main Seal for a 440? [Re: BloFish] #3147961
06/01/23 10:19 AM
06/01/23 10:19 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I am going to start replacing the rear main on the 440 in the Ramcharger, Dan at performance only did the bottom end, and I was about 15 years younder, and didnt assemble it with a rope seal, it leaks BAD!, Im doing this in the truck, thank god its a lifted 4x4, and the pan comes out easily. BUT with that said, Im a one man show, and Im curious if anyone has ever taken the main caps loose and let the crank drop a bit to aid in installing the new seal. Or will that cause a front pump seal issue on the tranny?
I have bought the Lisle sneaky pete tool, and I also plan on swaping the billet rear seal retainer with a OE retainer I have. I am also going to use the Mancini racing 1 piece gasket/windage trey for the oil pan gasket.
Has anyone ever drilled a few drain back holes in the plastic trey? I see they dont really have much of anything for drain back holes.
Kasey
Re: The best Rear main Seal for a 440? [Re: Moparnut426] #3147976
06/01/23 12:39 PM
06/01/23 12:39 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Replacing a two piece seal with another two piece seal? I was able to push out an old two piece seal and push in a new two piece seal without touching the main caps. The Mancini windage tray looks like the same as the Summit one I use unmodified and I haven’t had any issues shruggy
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: The best Rear main Seal for a 440? [Re: metallicareload] #3147990
06/01/23 01:30 PM
06/01/23 01:30 PM
Moparnut426 Offline
Moparnut426  Offline
Im taking the old Viton seal out that leaks like a sieve, and putting the correct rope seal in place, and have had issues getting them pulled in place.
Re: The best Rear main Seal for a 440? [Re: Moparnut426] #3147996
06/01/23 02:26 PM
06/01/23 02:26 PM
Anchorage, Alaska
Anchorage, Alaska
I see, I’m no help there
440, 4-Speed, 3.54
Re: The best Rear main Seal for a 440? [Re: Moparnut426] #3148015
06/01/23 03:59 PM
06/01/23 03:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I’m pretty sure you’re not going to pull a rope seal around the crank. Rope seal has to be put in the block first then seated with a special saddle tool, then trimmed. Is the crank journal knurled?
Re: The best Rear main Seal for a 440? [Re: HOTMOPR] #3148020
06/01/23 04:13 PM
06/01/23 04:13 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
How many have used the fast fish one piece seal? I have one leaking and thought about going this route, but id like some reviews on how they have worked out.
Matt
Re: The best Rear main Seal for a 440? [Re: mattsmopars] #3148033
06/01/23 05:53 PM
06/01/23 05:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Mine leaked a little on the dyno. Installed as directions said. Threw it away, put in a felpro black seal, staggered parting line about 3/8”, no leaky.
Re: The best Rear main Seal for a 440? [Re: mattsmopars] #3148311
06/02/23 09:17 PM
06/02/23 09:17 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Matt
I am a chevy guy so I openly accept rear seal leaks are part of the OEM rust protection package.... my only mopar is a junk 440, max piston to wall forged pistons, 0.030 - 0.035 ring end gap.... after several thousand miles on the street with a single pcv valve...zero rear seal leaks... the fast fish rear main is a f-ing miracle.
Re: The best Rear main Seal for a 440? [Re: Craig J] #3148337
06/02/23 11:24 PM
06/02/23 11:24 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
I'm curious how a billet rear main seal retainer is different / better than the OE piece.
Re: The best Rear main Seal for a 440? [Re: hemienvy] #3148342
06/03/23 02:30 AM
06/03/23 02:30 AM
i use adhesive silicone, not Gasket maker silicone tsk to seal up the seal holder between the block and the seal holder on both sides and smear it in between the seal holder and block on the bottom of the seal holder also. I use a narrow, thin, putty knife to do that wrench scope up
No main seal oil leaks for a long time on many (100+) B and RB, 426 hemi motors since doing that boogie grin
Re: The best Rear main Seal for a 440? [Re: Cab_Burge] #3148353
06/03/23 08:22 AM
06/03/23 08:22 AM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
My 470 is using the Fast Fish rear main seal. So far so good.
Page 3 of 4 1 2 3 4
