Re: The best Rear main Seal for a 440?
[Re: Cab_Burge]
#2830691
10/09/20 10:29 AM
10/09/20 10:29 AM
Posts: 1,318 Ohio
jlatessa
Ohio
I bought the 71 NYer from a person I knew and was from my town.
He was an older gentleman who bought the car new and was not one to lie when he said the engine was as he bought it and ran fine until he had to give up driving because of eyesight problems
The rear baffle as you see does not look like someone cobbled it together, it looks purpose built for that application.
I am of the opinion it is stock.
My 2 cents....Joe
PS the rear baffle is sheet metal, It just looks like a thick piece of steel. I had to be formed in a die specifically for that part.
[Re: jlatessa]
#2830865
10/09/20 05:15 PM
10/09/20 05:15 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
My 2 cents....Joe
I should have been clearer that I have not seen a 187 pan with any baffles in them but all of the ones i have bought and used where from pre 1971 cars I have seen both of those baffles used in later year oil pans on the Cordoba motors, but they weren't 187 stamp pans This is another good example to never say never when it comes to things car makers have done on production parts OP, do the spot welds on the rear baffle look exactly like the ones on the pump baffle?
[Re: Cab_Burge]
#2830870
10/09/20 05:20 PM
10/09/20 05:20 PM
Posts: 1,318 Ohio
jlatessa
Ohio
No room to beneath the baffle to get a spotweld tip in there, it is brazed.
Joe
Well, so much for my eyes, after cleaning, I can see the spotwelds too!, but smaller than the sump welds
[Re: Cab_Burge]
#2832157
10/12/20 11:22 PM
10/12/20 11:22 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Fast fish one piece rear seal and a billet retainer with the dual side seals per side..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: TrackPack]
#2832485
10/13/20 09:47 PM
10/13/20 09:47 PM
Cab_Burge
I think that is a stock RB,B 1967 to 1969 A body oil pan. Not a stock 1966 to 1972 C body oil pan
[Re: BloFish]
#3147961
06/01/23 10:19 AM
06/01/23 10:19 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
I am going to start replacing the rear main on the 440 in the Ramcharger, Dan at performance only did the bottom end, and I was about 15 years younder, and didnt assemble it with a rope seal, it leaks BAD!, Im doing this in the truck, thank god its a lifted 4x4, and the pan comes out easily. BUT with that said, Im a one man show, and Im curious if anyone has ever taken the main caps loose and let the crank drop a bit to aid in installing the new seal. Or will that cause a front pump seal issue on the tranny?
I have bought the Lisle sneaky pete tool, and I also plan on swaping the billet rear seal retainer with a OE retainer I have. I am also going to use the Mancini racing 1 piece gasket/windage trey for the oil pan gasket.
Has anyone ever drilled a few drain back holes in the plastic trey? I see they dont really have much of anything for drain back holes.
Kasey
[Re: HOTMOPR]
#3148020
06/01/23 04:13 PM
06/01/23 04:13 PM
Posts: 3,141 tennessee,usa
mattsmopars
tennessee,usa
Fast fish one piece rear seal and a billet retainer with the dual side seals per side.. How many have used the fast fish one piece seal? I have one leaking and thought about going this route, but id like some reviews on how they have worked out. Matt
[Re: mattsmopars]
#3148311
06/02/23 09:17 PM
06/02/23 09:17 PM
Posts: 167 West Palm Beach, Florida
Craig J
Fast fish one piece rear seal and a billet retainer with the dual side seals per side.. How many have used the fast fish one piece seal? I have one leaking and thought about going this route, but id like some reviews on how they have worked out. Matt I am a chevy guy so I openly accept rear seal leaks are part of the OEM rust protection package.... my only mopar is a junk 440, max piston to wall forged pistons, 0.030 - 0.035 ring end gap.... after several thousand miles on the street with a single pcv valve...zero rear seal leaks... the fast fish rear main is a f-ing miracle.
[Re: hemienvy]
#3148342
06/03/23 02:30 AM
06/03/23 02:30 AM
Cab_Burge
