Valve body part throttle upgrade and OD ? #3147244
05/28/23 02:20 PM
05/28/23 02:20 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
I have a 70 ? 727 in my 38 Ford with a TF-2 Kit. Is there an easy way to add the part throttle downshift feature or does it opem a can of worms?
I've also been contemplating upgrading to an OD trans or gear vendors unit. This question may be best asked in the street rod section but thought i would start here.
I'm not to up to date on the OD tranny's. So I'm not even sure what I should look at if I decided to go that way. i will sy the 727 is a snug fit in the tailshaft area as Ford used an X member in their frames. The engine is a warmed over 340 so something that will take some abuse is required.
TIA
Re: Valve body part throttle upgrade and OD ? [Re: TJP] #3147256
05/28/23 03:39 PM
05/28/23 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Installing the early PTK module is as easy as removing the existing end plate and installing the module. If the later module is used, the screw at the red arrow needs to be removed or a screw with a thinner head installed (preferred).
Re: Valve body part throttle upgrade and OD ? [Re: John_Kunkel] #3147325
05/28/23 11:09 PM
05/28/23 11:09 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Thank You John. beer
Re: Valve body part throttle upgrade and OD ? [Re: TJP] #3147342
05/29/23 01:19 AM
05/29/23 01:19 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
A and A used to sell a kit that did what you want. You could do the needle in a haystack thing and find it in an early six cylinder trans. One of my luckiest finds ever was asking my trans guy if he had one. He literally reached about three feet away and pulled out a complete setup. He said it had laid there for many years just in case. He rebuilt them all, but he was about as hardcore a mopar guy as you’ll meet.
I want my fair share
Re: Valve body part throttle upgrade and OD ? [Re: SomeCarGuy] #3147372
05/29/23 09:14 AM
05/29/23 09:14 AM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
i dont want to start a p###ing match but what is the advantage of a ptk tf? i had a big block dart (not original) with a 67 727 with a shift kit and the detent in the pedal travel told me exactly when it would kick down. wouldnt that be a good thing to have?
Re: Valve body part throttle upgrade and OD ? [Re: ekim] #3147416
05/29/23 12:24 PM
05/29/23 12:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The detent you feel is near WOT while the PTK is, well, at part throttle. Advantage is it kicks down at much less throttle to prevent lugging the engine.
Mopar was the last of the Big Three to incorporate PTK across the entire line their AT's.
Re: Valve body part throttle upgrade and OD ? [Re: John_Kunkel] #3147437
05/29/23 02:15 PM
05/29/23 02:15 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
all the other rwd mopars that i had did not have a detent that i could feel, maybe i just didnt notice it?
Re: Valve body part throttle upgrade and OD ? [Re: ekim] #3150050
06/09/23 03:45 PM
06/09/23 03:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would think a big block in a dart probably would do fine without the need for the kick down very often.
A slant 6 or a 318 in a B or C body is a different matter (especially in the 70s when lots of cars got stuck with 2:76 or even worse, the 80s with 2:45 gears).. That part time kickdown was a nice addition. You didn't have to floor it every time to get the trans to downshift for that extra kick.
it made a few powerless slugs at least somewhat drivable.
Re: Valve body part throttle upgrade and OD ? [Re: poorboy] #3150129
06/09/23 11:11 PM
06/09/23 11:11 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
The other app is a cammed motor that is a bit lazy below 2500 RPM wink
