727 Trans Expert Needed #3146219
05/22/23 05:13 PM
05/22/23 05:13 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I have a good working 727 trans out of a '78 Dodge truck with a 318 that I installed in a hopped up 1972 Challenger with a 340. All external band and linkage adjustments have been checked and kickdown lever is set to hit the back of the stop at WOT. Problem is the max shift point I can coax out of the trans is about 5000 RPMs while leaving shifter in drive. I'd like to raise the shift points closer to 6000 RPMs. Do I need to swap out and install a performance valve body, or governor weight, or is there something else I can do to raise shift points?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3146228
05/22/23 06:08 PM
05/22/23 06:08 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Re: 727 Trans Expert Needed [Re: 469runner] #3146287
05/22/23 10:32 PM
05/22/23 10:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A transgo TF-2 kit should also work wink up
Re: 727 Trans Expert Needed [Re: TJP] #3146297
05/23/23 12:03 AM
05/23/23 12:03 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 727 Trans Expert Needed [Re: BloFish] #3146342
05/23/23 09:25 AM
05/23/23 09:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The Trans-Go TF-2 kit will let you manually shift at whatever rpm you choose.
If you want it to shift at 6k rpm on its own (while in Drive) get the lighter weight governor kit from A&A.
'63 Dodge 330
11.19 @ 121 mph
Re: 727 Trans Expert Needed [Re: GY3] #3146428
05/23/23 04:28 PM
05/23/23 04:28 PM
NW New Jersey
NW New Jersey
I think my problem is deeper than I originally thought. Took it out for the first time this year and with the pedal smashed to the floor, 1-2 upshift occurs at 2700 RPMs and 2-3 upshift occurs at 3200 RPMs. Checked kickdown lever and it's all the way back to the stop. Going to check line pressure next to see if pump is okay. Any other suggestions?
Re: 727 Trans Expert Needed [Re: GY3] #3146478
05/23/23 09:45 PM
05/23/23 09:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
i have installed many TF-2 kits over the years and have always been able to set the WOT upshift points by adjusting the KD linkage. The governor kit is another way to go beer
Re: 727 Trans Expert Needed [Re: TJP] #3146527
05/24/23 07:32 AM
05/24/23 07:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The low WOT at close to 5000 is actually pretty good for a stock low performance governor. However the fact that it now around 3000 is not right. My thinking is a stuck valve. I put a TF2 kit in it since The VB probably needs to be cleaned anyway. Then test. You can juggled shift valve springs to alter shift rpm in D. But in the big picture it may take a governor swap.
Doug
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3146610
05/24/23 01:20 PM
05/24/23 01:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the throttle lever full back is the stop firm? On rare occasions the weld at the end of the throttle lever shaft will break loose from the cam and cause early shifts.
Re: 727 Trans Expert Needed [Re: John_Kunkel] #3146883
05/26/23 07:58 AM
05/26/23 07:58 AM
NW New Jersey
NW New Jersey
Feels pretty firm to me but I'll double check. I ordered the T2 kit and will try installing it this weekend. Figured I'd replace the shifter shaft seal while I'm at it. Anything I should be looking for while I have the Valve Body out?
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3146889
05/26/23 08:56 AM
05/26/23 08:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Get the govenor weights , it's still going to shift lower than you'd like .
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3146894
05/26/23 09:25 AM
05/26/23 09:25 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Double check to make sure your low/reverse band servo shaft 30 cent o ring is not leaking on the backside of transmission while you have the valve body out
You just have to remove the transmission mount and six bolts for tail shaft housing and rotate the tail shaft slightly to clear the tab
Just did this on my 71 Superbee after the transmission shop did not replace that o ring five years ago - It was hard and brittle
Fun laying on my back in the garage
Amazing how much of a mess that little o ring can leave on the garage floor after a winter hibernation
Trans shop did give me the o rings for free along with a newer servo shaft out of an overdrive transmission with double grooves or two o rings
Not a drop since but not a fun job to say the least on your back
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 727 Trans Expert Needed [Re: bee1971] #3146945
05/26/23 02:38 PM
05/26/23 02:38 PM
moparx Offline
moparx  Offline
after that o-ring is replaced, and before the tail shaft is bolted on, i like to fill the hole behind the shaft that is visible to the outside of the case with either clear silicone sealant or high temperature rtv even with the case surface.
this may not be necessary, but you won't have any worries about seeping or leaks from that shaft.
beer
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3147001
05/26/23 10:46 PM
05/26/23 10:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Do the kick down shaft seal as well. I've done many TF-2 kits and had no issues getting 6-6500 RPM WOT shift points shruggy
Re: 727 Trans Expert Needed [Re: bee1971] #3147047
05/27/23 11:56 AM
05/27/23 11:56 AM
NW New Jersey
NW New Jersey
Where is this located? Pictures?
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3147048
05/27/23 11:58 AM
05/27/23 11:58 AM
NW New Jersey
NW New Jersey
TF-2 will arrive today. I'll start with that and if shift points don't improve enough, I'll change the gov weights.
Re: 727 Trans Expert Needed [Re: RSI700VIPER] #3147060
05/27/23 01:06 PM
05/27/23 01:06 PM
moparx Offline
moparx  Offline
please pick up the book : Torqueflight A-727, Transmission Handbook [How to rebuild or modify Chrysler's A-727 Torqueflight for all applications] by Carl H. Munroe.
it's a great handbook, and does a step by step TF-2 installation with pictures, starting on page 165.
it also details the rebuild process, as well as anything else you may want to learn about this transmission.
well worth the price.
https://www.amazon.com/Torqueflite-727-Transmission-Handbook-HP1399/dp/1557883998/ref=sr_1_2?
beer
Re: 727 Trans Expert Needed [Re: moparx] #3147148
05/27/23 11:15 PM
05/27/23 11:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
might well be good advice as Trans go's Instructions used to be like walking a drunk duck. Loved the kits, but the instructions should have been written for a Dyson or Shark as they Sucked real well. Maybe they've redone them shruggy
Re: 727 Trans Expert Needed [Re: TJP] #3147376
05/29/23 09:26 AM
05/29/23 09:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
beer
I've found Trans Go's instructions very easy. Their tech line is great as well.
Doug
Re: 727 Trans Expert Needed [Re: dvw] #3147412
05/29/23 12:14 PM
05/29/23 12:14 PM
moparx Offline
moparx  Offline
although trans-go's instructions are somewhat goofy, i'm like Doug, i haven't had any trouble at all following them, and the end result worked great.
but then again, i've been told many times over my lifetime i'm kind'a goofy............ biggrin
beer
