What do I need to do to make a 46rh transmission work in a 03 dodge dakota. The truck currently has a 42re. I am installing a 318/390 stroker.Thanks for any help.
Why wouldn't you use the existing trans? They hold up better and can easily be modified to handle more power, have a lot less weight, lot lighter rotating parts, lower 1st and second gears for better low speed TQ at the wheels but the same OD ratio so MPG is the same or even better plus you don't have to swap driveshaft(s), wiring, dipstick tube... and are noticeably faster, easier to install
