46rh trans in a 03 dakota #3145358
05/18/23 03:34 PM
05/18/23 03:34 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
What do I need to do to make a 46rh transmission work in a 03 dodge dakota. The truck currently has a 42re. I am installing a 318/390 stroker.Thanks for any help.
Re: 46rh trans in a 03 dakota [Re: merpar] #3145529
05/19/23 10:23 AM
05/19/23 10:23 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
You'll need an RE series. 96 and newer.
Carl Kessel
Re: 46rh trans in a 03 dakota [Re: merpar] #3145540
05/19/23 11:40 AM
05/19/23 11:40 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Why wouldn't you use the existing trans? They hold up better and can easily be modified to handle more power, have a lot less weight, lot lighter rotating parts, lower 1st and second gears for better low speed TQ at the wheels but the same OD ratio so MPG is the same or even better plus you don't have to swap driveshaft(s), wiring, dipstick tube... and are noticeably faster, easier to install
Re: 46rh trans in a 03 dakota [Re: HotRodDave] #3145740
05/20/23 10:15 AM
05/20/23 10:15 AM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Everything I read says they are too weak. And haven't seen anyone offering a build kit with mods to beef it up. You possibly know of someone?
Re: 46rh trans in a 03 dakota [Re: merpar] #3145797
05/20/23 02:10 PM
05/20/23 02:10 PM
A727Tflite Online content
A727Tflite  Online Content
x
Re: 46rh trans in a 03 dakota [Re: HotRodDave] #3146133
05/22/23 10:01 AM
05/22/23 10:01 AM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
Thanks Dave, I guess I'm still in the drag race mode. You gave me some logical info. I'm not going to race the Dakota, so no trans brake or anything to shock it. Just a street rod, I have built all the transmissions for my race cars plus my dodge cummins. I'll be 80 next month and guess I didn't want to mess with it. Just need to find a good rebuild kit. Thanks for opening my eyes Dave.
