W9 Valve Spring Recommendation #3145042
05/16/23 09:25 PM
05/16/23 09:25 PM
WNY
Moparrob68 Offline OP
WNY
While inspecting the W9 engine after last weeks Dyno session we found a broken intake valve spring. Looking for a recommendation for a good set of springs that will last in a bracket engine.
0.730 lift solid roller cam
2.15 Intake 1.62 Exhaust Titanium Valves
7800 RPM redline
Current springs: PSI 1.58 OD 250 lbs @ 1.94 " 690 lbs @ 1.21"
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3145047
05/16/23 10:07 PM
05/16/23 10:07 PM
SoCal
Brian Hafliger Offline
SoCal
Probably not the springs fault...looks like your way off coil bind at max lift. You have to check lift at the valve with springs you plan to run, with lash adjusted. So if you have .700 at the valve, your waaaaay off of coil bind. You need to be around .050 off coil bind.
Brian Hafliger
Re: W9 Valve Spring Recommendation [Re: Brian Hafliger] #3145055
05/16/23 10:33 PM
05/16/23 10:33 PM
WNY
WNY
That's a picture of the broken spring with the valve closed.
Springs were installed @ 1.925 that = 0.050 off of coil bind of 1.15
1.15+0.730+0.050=1.93
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3145058
05/16/23 11:00 PM
05/16/23 11:00 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Hi Rob. I think you have coil bind problems. what part number are your psi springs.
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3145060
05/16/23 11:16 PM
05/16/23 11:16 PM
SoCal
SoCal
Did you check valve lift with the springs installed and lash? Your not at .730!
Brian Hafliger
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3145074
05/17/23 03:12 AM
05/17/23 03:12 AM
i like and use PAC 1300 series valve springs on my solid roller bracket motors, 1200 series on street motors with solid roller cams up scope wrench up
Re: W9 Valve Spring Recommendation [Re: Cab_Burge] #3145084
05/17/23 08:04 AM
05/17/23 08:04 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
i like the comp 944, set up at 1.89. But they require a .810 inner step retainer, which is a bit goofy. I would only consider them if your retainers are compatible.
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3145100
05/17/23 09:21 AM
05/17/23 09:21 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d call and talk to PSI and get some feedback from them.
They might offer a more premium version of that spring, then it would be a “drop in”.
Re: W9 Valve Spring Recommendation [Re: fast68plymouth] #3145188
05/17/23 07:11 PM
05/17/23 07:11 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Or speak with Joe Hornick Enterprises
PSI are probably some of the best springs on the market. If the valve spring broke, something is not happy in your valvetrain
Alan Jones
Re: W9 Valve Spring Recommendation [Re: Moparrob68] #3151063
06/13/23 05:07 AM
06/13/23 05:07 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
What Brian Hafliger is saying mate is 442 cam lobe x 1.65 rocker =729 lift - 020 lash and -030 deflexion gives your net lift 669 , 1.925 installed height - coilbind 1.15 -. 669 net lift leaves .106 to coil bind , i did say i think those springs were of in our email
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
