Probably not the springs fault...looks like your way off coil bind at max lift. You have to check lift at the valve with springs you plan to run, with lash adjusted. So if you have .700 at the valve, your waaaaay off of coil bind. You need to be around .050 off coil bind.
Brian Hafliger
