W9 Valve Spring Recommendation
#3145042
05/16/23 09:25 PM
05/16/23 09:25 PM
Posts: 108 WNY
Moparrob68
WNY
While inspecting the W9 engine after last weeks Dyno session we found a broken intake valve spring. Looking for a recommendation for a good set of springs that will last in a bracket engine.
0.730 lift solid roller cam 2.15 Intake 1.62 Exhaust Titanium Valves 7800 RPM redline Current springs: PSI 1.58 OD 250 lbs @ 1.94 " 690 lbs @ 1.21"
Re: W9 Valve Spring Recommendation
[Re: Moparrob68]
#3145047
05/16/23 10:07 PM
05/16/23 10:07 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Probably not the springs fault...looks like your way off coil bind at max lift. You have to check lift at the valve with springs you plan to run, with lash adjusted. So if you have .700 at the valve, your waaaaay off of coil bind. You need to be around .050 off coil bind.
Brian Hafliger
[Re: Brian Hafliger]
#3145055
05/16/23 10:33 PM
05/16/23 10:33 PM
Posts: 108 WNY
Moparrob68
WNY
That's a picture of the broken spring with the valve closed. Springs were installed @ 1.925 that = 0.050 off of coil bind of 1.15 1.15+0.730+0.050=1.93
[Re: Moparrob68]
#3145060
05/16/23 11:16 PM
05/16/23 11:16 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Did you check valve lift with the springs installed and lash? Your not at .730!
Brian Hafliger
[Re: Moparrob68]
#3145100
05/17/23 09:21 AM
05/17/23 09:21 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d call and talk to PSI and get some feedback from them. They might offer a more premium version of that spring, then it would be a “drop in”.
[Re: fast68plymouth]
#3145188
05/17/23 07:11 PM
05/17/23 07:11 PM
Posts: 6,148 Melbourne , Australia
LA360
I’d call and talk to PSI and get some feedback from them. They might offer a more premium version of that spring, then it would be a “drop in”. Or speak with Joe Hornick Enterprises PSI are probably some of the best springs on the market. If the valve spring broke, something is not happy in your valvetrain
Alan Jones
