Re: School me on turbos.
[Re: migsBIG]
#3144605
05/14/23 07:22 PM
05/14/23 07:22 PM
Posts: 876 Missouri
jwb123
Missouri
For what it is worth this is my advice. The proper sizing of the turbo is VERY important. especially if you are buying or building a cheaper Ebay style kit. Turbo too small spools to quick hard on turbos, and the parts going through an engine when the impeller lets go is very bad. Turbo too big no power down low lots of lag, and only makes boost at higher rpm's. Lots to read on the internet this page will give the basics. https://www.garrettmotion.com/racing-and-performance/choosing-a-turbocharger/ If you are doing an older style engine some way to control the timing with a computer is a must. Plus a computer controlled boost regulation of some kind as well. Intercooler always makes more power less detonation.
[Re: racerx]
#3144735
05/15/23 12:15 PM
05/15/23 12:15 PM
Posts: 4,565 Motor City
6PKRTSE
Motor City
Someday in the queue for one of my next builds. T.T. Keith Black Hemi
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3144739
05/15/23 12:46 PM
05/15/23 12:46 PM
Posts: 712 Lake Villa Il
INTMD8
Lake Villa Il
Might be easier to start with, what are you goals/what do you want to build?
I always prefer twins. Turbo combos can be some of the most reliable stuff you can build, IMO.
[Re: migsBIG]
#3144761
05/15/23 02:42 PM
05/15/23 02:42 PM
Posts: 911 London, England
mopar_mark
London, England
My friends talk about turbos all the time on late model stuff, but I’m completely in the dart on vintage cars and drivetrains with the super snails. So here are a few questions.
How much maintenance are single/dual set ups? Liquid/air cooled? Compression needed for street/strip? Comparable costs to blower/power adders? Intercooler? Water/meth injection? Fuel type? Looking over on eBay, seems they offer single/duel turbos for all mopars except the big block. Are big blocks with turbos good or bad, or just a lack of demand on this set up? Thanks for any info.
No real turbo maintenance issues, key being good oil supply to bearings, keeping engine running after a hard pass, to allow oil supply to bearings while cooling. launching/ spooling a turbo can be a lot harder on parts such as Trans Converter I don’t know anyone using watercooled, that’s not to say they are not good, but not common Compression ratio is also dependant on fuel choice, engine hardware, 9:1 is a good starting base Cost really depends on quality of parts chosen, power levels, etc. Have to factor in other items, Exhausts, Waste gates, BOVs, Boost Ref Regulator, Boost Controller, Lambdas, etc, etc Intercooler choice really depends on your end goals, what fuels you intend to use I’m guessing there are less Mopar Turbo Kits due to popularity, when compared to say Chevrolet. My advise would be to take a proper look at installs on cars, irrelevant if make, speak to some of the owners, talks to turbo companies, even contact respected shops/ fabricators on turbo installs
[Re: Uberpube]
#3145195
05/17/23 07:39 PM
05/17/23 07:39 PM
Posts: 21,644 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
The question becomes do you just want to boost an n/a combo to it's limit, or do you want to build a dedicated turbo engine? Im thinking a dependable system with with fuel injection. Something that makes good power without being ‘race only’. Not trying to be King of the track or even bragging right in the parking lot. Fun, torqie, application that makes driving to events fun and if I get on the track, not completely embarrassing.
[Re: TheOtherDodge]
#3145695
05/20/23 12:49 AM
05/20/23 12:49 AM
migsBIG
San Jose,CA
I will ask again.... what vehicle weight, what ET estimates? Right now, your range is 6.5's to 12.0's. We have several cars to work with, so can't really decide on one til we measure engine bays and see what parts are on the shelves and budget to be calculated. WE have a duster, 2nd gen dart, a challenger, 3rd gen charger and possibly a couple 2nd gen b-bodies by next month if a deal gets made. Appreciate your thoughts on anything. If it gets into 10's with the wind pushing from behind is cool. I know you can build a NAE to that speed, but don't want an all out brawler of an engine. Not the kind of engine that you have to pop a laptop open on after your trip to the local Dairy Queen.
[Re: migsBIG]
#3145789
05/20/23 01:49 PM
05/20/23 01:49 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
You will accidentally get into the 10's with a headwind at 100 degrees.
For example, my goal (12 years ago) was to have a fully streetable truck, pump gas, ac, ps, pb, full interior, muffler etc., and run in the 10's. First pass out I went 10.3's with a cheap 76 mm turbo, .520 hydraulic roller, 3.55 gear and no boost controller. I have since gone mid 9's with that combo and a boost controller. Granted, you need to have a well sorted combo but it is not hard to do.
[Re: TheOtherDodge]
#3146054
05/21/23 07:46 PM
05/21/23 07:46 PM
Posts: 4,206 New York
polyspheric
New York
The easiest and cheapest plan is to duplicate somebody's successful project. The odds of getting it right on your own the first, or 5th time, are not good. It's much more complicated than a N/A engine, minor tuning changes are worth 100 hp, or a big explosion. Otherwise, I can suggest 10 or 15 books you can go through...
Boffin Emeritus
[Re: polyspheric]
#3146156
05/22/23 11:51 AM
05/22/23 11:51 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
The easiest and cheapest plan is to duplicate somebody's successful project. The odds of getting it right on your own the first, or 5th time, are not good. It's much more complicated than a N/A engine, minor tuning changes are worth 100 hp, or a big explosion. Otherwise, I can suggest 10 or 15 books you can go through... That is VERY wise advice. Doing my turbo deal over 10 years I wiped out many bearings, 2 sets of pistons, cracked a set of heads, warped valves, etc... Either learn from those of us on the board who did it with similar goals, or suffer the steep learning curve!
[Re: polyspheric]
#3146158
05/22/23 12:13 PM
05/22/23 12:13 PM
Posts: 8,247 fredericksburg,va
cudaman1969
fredericksburg,va
The easiest and cheapest plan is to duplicate somebody's successful project. The odds of getting it right on your own the first, or 5th time, are not good. It's much more complicated than a N/A engine, minor tuning changes are worth 100 hp, or a big explosion. Otherwise, I can suggest 10 or 15 books you can go through... Exactly, starting on the weaker side saves parts, someone will always buy the used parts as you get stronger.
[Re: migsBIG]
#3146223
05/22/23 05:46 PM
05/22/23 05:46 PM
polyspheric
New York
I wimped out. I wanted a turbo project, so I got a factory-turbo Toyota engine for my Lexus. The upgrade instructions and parts lists are everywhere to add up to about 700 hp to the stock 320 hp (the engines is 30 years old), including which stock parts are more than good enough (head, block, crank, oil), which $$$ mods return little value for cost, etc.
First: what's the goal? Hot street? Bracket? DD? What's the budget?
Boffin Emeritus
