School me on turbos. #3144594
05/14/23 06:44 PM
05/14/23 06:44 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
My friends talk about turbos all the time on late model stuff, but I’m completely in the dart on vintage cars and drivetrains with the super snails. So here are a few questions.
How much maintenance are single/dual set ups?
Liquid/air cooled?
Compression needed for street/strip?
Comparable costs to blower/power adders?
Intercooler? Water/meth injection? Fuel type?
Looking over on eBay, seems they offer single/duel turbos for all mopars except the big block. Are big blocks with turbos good or bad, or just a lack of demand on this set up?
Thanks for any info.
Re: School me on turbos. [Re: migsBIG] #3144605
05/14/23 07:22 PM
05/14/23 07:22 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
For what it is worth this is my advice. The proper sizing of the turbo is VERY important. especially if you are buying or building a cheaper Ebay style kit. Turbo too small spools to quick hard on turbos, and the parts going through an engine when the impeller lets go is very bad. Turbo too big no power down low lots of lag, and only makes boost at higher rpm's. Lots to read on the internet this page will give the basics. https://www.garrettmotion.com/racing-and-performance/choosing-a-turbocharger/ If you are doing an older style engine some way to control the timing with a computer is a must. Plus a computer controlled boost regulation of some kind as well. Intercooler always makes more power less detonation.
Re: School me on turbos. [Re: migsBIG] #3144644
05/15/23 05:40 AM
05/15/23 05:40 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'm in the process of doing twins on a BB, still has a good way to go tho. I'm doing dual cheap chines 88's.Don't no if you do FB but there's a group over there call RWDBoosted Mopar you probably get more response to your question there.
Re: School me on turbos. [Re: racerx] #3144735
05/15/23 12:15 PM
05/15/23 12:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Someday in the queue for one of my next builds. T.T. Keith Black Hemi
100_1454 (2).jpg100_1453 [640x480].jpg100_1456 [640x480].jpg100_1455 [640x480].jpg
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: School me on turbos. [Re: 6PKRTSE] #3144739
05/15/23 12:46 PM
05/15/23 12:46 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Might be easier to start with, what are you goals/what do you want to build?
I always prefer twins. Turbo combos can be some of the most reliable stuff you can build, IMO.
Re: School me on turbos. [Re: migsBIG] #3144761
05/15/23 02:42 PM
05/15/23 02:42 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Liquid/air cooled?
No real turbo maintenance issues, key being good oil supply to bearings, keeping engine running after a hard pass, to allow oil supply to bearings while cooling. launching/ spooling a turbo can be a lot harder on parts such as Trans Converter
I don’t know anyone using watercooled, that’s not to say they are not good, but not common
Compression ratio is also dependant on fuel choice, engine hardware, 9:1 is a good starting base
Cost really depends on quality of parts chosen, power levels, etc. Have to factor in other items, Exhausts, Waste gates, BOVs, Boost Ref Regulator, Boost Controller, Lambdas, etc, etc
Intercooler choice really depends on your end goals, what fuels you intend to use
I’m guessing there are less Mopar Turbo Kits due to popularity, when compared to say Chevrolet. My advise would be to take a proper look at installs on cars, irrelevant if make, speak to some of the owners, talks to turbo companies, even contact respected shops/ fabricators on turbo installs
Re: School me on turbos. [Re: migsBIG] #3144771
05/15/23 03:31 PM
05/15/23 03:31 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Best to provide a vehicle weight and the goals as there are too many different ways to get there.
For me, I prefer a single turbo, air to air in a street driven vehicle. No turbo/extra maintenance. Only normal "vehicle" maintenance.
The main benefit about a turbo is you can keep gearing/converter/camshaft size down (assuming less than 1,000 hp) making it much more streetable than many other power adders, including N/A builds.
Re: School me on turbos. [Re: TheOtherDodge] #3144785
05/15/23 05:04 PM
05/15/23 05:04 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
https://youtu.be/BuzaBfzSK1I
Single. 440-1 heads. Indy block. 440source crank. FAST EFI. Bunch of junk. Been 4.80 at 162 MPH 1/8 mile. Chute out been 7.60 on the breaks lmao
The anouncer was excited at the end of this one.
Re: School me on turbos. [Re: FastmOp] #3144830
05/15/23 09:48 PM
05/15/23 09:48 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The question becomes do you just want to boost an n/a combo to it's limit, or do you want to build a dedicated turbo engine?
Re: School me on turbos. [Re: Uberpube] #3145195
05/17/23 07:39 PM
05/17/23 07:39 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Im thinking a dependable system with with fuel injection. Something that makes good power without being ‘race only’. Not trying to be King of the track or even bragging right in the parking lot. Fun, torqie, application that makes driving to events fun and if I get on the track, not completely embarrassing.
Re: School me on turbos. [Re: migsBIG] #3145302
05/18/23 11:54 AM
05/18/23 11:54 AM
Houston, Texas
Houston, Texas
I will ask again.... what vehicle weight, what ET estimates? Right now, your range is 6.5's to 12.0's. confused
Re: School me on turbos. [Re: TheOtherDodge] #3145695
05/20/23 12:49 AM
05/20/23 12:49 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
We have several cars to work with, so can't really decide on one til we measure engine bays and see what parts are on the shelves and budget to be calculated. WE have a duster, 2nd gen dart, a challenger, 3rd gen charger and possibly a couple 2nd gen b-bodies by next month if a deal gets made. Appreciate your thoughts on anything. If it gets into 10's with the wind pushing from behind is cool. I know you can build a NAE to that speed, but don't want an all out brawler of an engine. Not the kind of engine that you have to pop a laptop open on after your trip to the local Dairy Queen.
Re: School me on turbos. [Re: migsBIG] #3145789
05/20/23 01:49 PM
05/20/23 01:49 PM
Houston, Texas
Houston, Texas
You will accidentally get into the 10's with a headwind at 100 degrees.
For example, my goal (12 years ago) was to have a fully streetable truck, pump gas, ac, ps, pb, full interior, muffler etc., and run in the 10's. First pass out I went 10.3's with a cheap 76 mm turbo, .520 hydraulic roller, 3.55 gear and no boost controller. I have since gone mid 9's with that combo and a boost controller. Granted, you need to have a well sorted combo but it is not hard to do.
Re: School me on turbos. [Re: TheOtherDodge] #3145811
05/20/23 02:53 PM
05/20/23 02:53 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That there is the most hated question in all of engine talk for me. Anyone with common sense knows you don’t put on a turbo bigger than the engine. NO ONE has the correct answer so Whatever comes out, work it from there. My advice, look at what the generic ‘kits’ fits no matter the brand, find out what YOUR engine likes then buy the $$$ parts.
Re: School me on turbos. [Re: cudaman1969] #3146025
05/21/23 03:59 PM
05/21/23 03:59 PM
Houston, Texas
Houston, Texas
No one has the correct answer? LOL wave
Re: School me on turbos. [Re: TheOtherDodge] #3146054
05/21/23 07:46 PM
05/21/23 07:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The easiest and cheapest plan is to duplicate somebody's successful project.
The odds of getting it right on your own the first, or 5th time, are not good. It's much more complicated than a N/A engine, minor tuning changes are worth 100 hp, or a big explosion.
Otherwise, I can suggest 10 or 15 books you can go through...
Boffin Emeritus
Re: School me on turbos. [Re: polyspheric] #3146156
05/22/23 11:51 AM
05/22/23 11:51 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That is VERY wise advice. Doing my turbo deal over 10 years I wiped out many bearings, 2 sets of pistons, cracked a set of heads, warped valves, etc... Either learn from those of us on the board who did it with similar goals, or suffer the steep learning curve!
Re: School me on turbos. [Re: polyspheric] #3146158
05/22/23 12:13 PM
05/22/23 12:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Exactly, starting on the weaker side saves parts, someone will always buy the used parts as you get stronger.
Re: School me on turbos. [Re: cudaman1969] #3146221
05/22/23 05:34 PM
05/22/23 05:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I poured the coals to mine. Was told don't be a b!tch. But I was trying to go fast ,still not happy with it. Got the MPH for .40s. but only a 1.12 sixty. Putting Holley on it now. The Fast stuff is coming off and going on a procharged gen 3 hemi in my Road Runner . I guess I do more boosted stuff then most.
Re: School me on turbos. [Re: migsBIG] #3146223
05/22/23 05:46 PM
05/22/23 05:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I wimped out.
I wanted a turbo project, so I got a factory-turbo Toyota engine for my Lexus. The upgrade instructions and parts lists are everywhere to add up to about 700 hp to the stock 320 hp (the engines is 30 years old), including which stock parts are more than good enough (head, block, crank, oil), which $$$ mods return little value for cost, etc.
First: what's the goal? Hot street? Bracket? DD?
What's the budget?
Boffin Emeritus
