Re: Correct Torque Converter
[Re: jim6346]
#3142295
05/03/23 02:51 PM
05/03/23 02:51 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You can buy a weighted flex plate that will allow you to use any neutral balance torque converter.
They are offered by B&M and others.
Just be sure to get the correct one for a cast crank 440.
[Re: fast68plymouth]
#3142299
05/03/23 03:12 PM
05/03/23 03:12 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All cast crank big blocks take the same external weight.
[Re: John_Kunkel]
#3142307
05/03/23 03:37 PM
05/03/23 03:37 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I think what Dwayne meant was to be sure to get the flexplate for a cast crank big block and not the externally balanced forged crank 440.
[Re: John_Kunkel]
#3142308
05/03/23 03:38 PM
05/03/23 03:38 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I think it was a 50 gram weight, I’d double check what was used by the factory and see about welding that on there before pulling the trans for the special flex plate, which is your only other choice.
I want my fair share
#3142323
05/03/23 04:27 PM
05/03/23 04:27 PM
Posts: 559 Newark Valley, NY
jim6346
Newark Valley, NY
Thanks everyone. I have to change the torque converter anyway, too high a stall. Looking for something closer to stock for easy cruising Not sure what to look for aftermarket? Thanks, Jim
[Re: jim6346]
#3142347
05/03/23 05:36 PM
05/03/23 05:36 PM
fast68plymouth
So. Burlington, Vt.
If the motor is basically stock, you could use a rebuilt factory 12” unit, like what would have come behind muscle car era 440’s.
If there are some hot rod items involved, particularly a performance cam........ something like a factory high stall 11” might be preferred.
Some of that choice comes down to personal preferences.
#3142443
05/04/23 08:40 AM
05/04/23 08:40 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Some of that choice comes down to personal preferences. And to make your life easier get the weighted flexplate that will open up your convertor choices.
[Re: JohnRR]
#3142461
05/04/23 10:03 AM
05/04/23 10:03 AM
an8sec70cuda
Some of that choice comes down to personal preferences. And to make your life easier get the weighted flexplate that will open up your convertor choices. B&M 10237 flexplate is what you need if you have a cast crank 440.
