Correct Torque Converter #3142290
05/03/23 02:32 PM
05/03/23 02:32 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi Everyone!
I have a 73 Challenger that we installed a 76 440 into. Got a bad vibration at idle and above.
It looks like I may have the wrong torque converter (no weights). The 440 is externally balanced, what would be
a good torque converter? Supplier?
Thanks,
Re: Correct Torque Converter [Re: jim6346] #3142295
05/03/23 02:51 PM
05/03/23 02:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You can buy a weighted flex plate that will allow you to use any neutral balance torque converter.
They are offered by B&M and others.
Just be sure to get the correct one for a cast crank 440.
Re: Correct Torque Converter [Re: fast68plymouth] #3142299
05/03/23 03:12 PM
05/03/23 03:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All cast crank big blocks take the same external weight.
Re: Correct Torque Converter [Re: John_Kunkel] #3142307
05/03/23 03:37 PM
05/03/23 03:37 PM
an8sec70cuda Offline
I think what Dwayne meant was to be sure to get the flexplate for a cast crank big block and not the externally balanced forged crank 440.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Correct Torque Converter [Re: John_Kunkel] #3142308
05/03/23 03:38 PM
05/03/23 03:38 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I think it was a 50 gram weight, I’d double check what was used by the factory and see about welding that on there before pulling the trans for the special flex plate, which is your only other choice.
I want my fair share
Re: Correct Torque Converter [Re: an8sec70cuda] #3142310
05/03/23 03:43 PM
05/03/23 03:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
Originally Posted by an8sec70cuda
I think what Dwayne meant was to be able sure to get the flexplate for a cast crank big block and not the externally balanced forged crank 440.
Or one for a 360, or cast crank 340.
https://www.holley.com/products/drivetrain/flexplates/b_and_m_flexplates/chrysler/parts/10237
440Source shows them as well.
Re: Correct Torque Converter [Re: fast68plymouth] #3142323
05/03/23 04:27 PM
05/03/23 04:27 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks everyone. I have to change the torque converter anyway, too high a stall. Looking for something
closer to stock for easy cruising smile Not sure what to look for aftermarket?
Thanks,
Re: Correct Torque Converter [Re: jim6346] #3142347
05/03/23 05:36 PM
05/03/23 05:36 PM
So. Burlington, Vt.
So. Burlington, Vt.
If the motor is basically stock, you could use a rebuilt factory 12” unit, like what would have come behind muscle car era 440’s.
If there are some hot rod items involved, particularly a performance cam........ something like a factory high stall 11” might be preferred.
Some of that choice comes down to personal preferences.
Re: Correct Torque Converter [Re: fast68plymouth] #3142443
05/04/23 08:40 AM
05/04/23 08:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And to make your life easier get the weighted flexplate that will open up your convertor choices.
Re: Correct Torque Converter [Re: JohnRR] #3142461
05/04/23 10:03 AM
05/04/23 10:03 AM
iagree B&M 10237 flexplate is what you need if you have a cast crank 440.
CHIP
