528 on the dyno #3134903
04/03/23 08:39 PM
04/03/23 08:39 PM
gregsdart Offline OP
Re: 528 on the dyno [Re: gregsdart] #3134906
04/03/23 08:46 PM
04/03/23 08:46 PM
Tim has a 1050 dominater that produced 865 hp, which he will probably run .
Re: 528 on the dyno [Re: gregsdart] #3134924
04/03/23 10:25 PM
04/03/23 10:25 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Nice numbers with -1's..
"Any fool can know. The point is to understand"
- A. Einstein
Re: 528 on the dyno [Re: EvilB1Dart] #3134965
04/04/23 07:51 AM
04/04/23 07:51 AM
NC
440Jim Offline
440Jim  Offline
NC
528 CID Looks like it made about 872hp at 7100 rpm, 723 ft-lbs at 5600 rpm
Indy 440-1 heads
13.6 CR
0.800" lift intake valve
Do you have any more specs?
4.500" bore?
Cam duration, LSA
Re: 528 on the dyno [Re: 440Jim] #3134969
04/04/23 08:16 AM
04/04/23 08:16 AM
Indy 440-1 heads
13.6 CR
4.500" bore?
Cam duration, LSA
Bore 4.500 rings . 9mm. No vacuum pump. C12fuel. Harland Sharp 1.6 rockers, 3/8 smith pusheods. Cam is over 280 on the intake, Tim was going to call me with full specs. Originally a Godwin spec'd design for 440-1 heads on a 497 i believe.
Re: 528 on the dyno [Re: gregsdart] #3134977
04/04/23 09:04 AM
04/04/23 09:04 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Nice combo.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 528 on the dyno [Re: 6PKRTSE] #3135886
04/06/23 10:58 AM
04/06/23 10:58 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
I have no idea what my 528 with -1s makes on the Dyno, but I know it runs really in my car and I love the combo.
My car weighs 2825 race ready last year. I added some tubing to the car over the winter so I don’t know how much weight I added but probably 10 lbs or so.
I just ran my fastest pass last weekend.
5.48 at 124mph. That was spinning. The following pass was an elimination pass, car hooked up great but I had to lift due to being ahead. Incrementals show I was on a 5.44-5.45 pass.
Engine built by Tim Bowman at Bowman Performance.
Re: 528 on the dyno [Re: 71Demon528] #3136148
04/07/23 09:31 AM
04/07/23 09:31 AM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
What transmission and rear gears are you using?
Re: 528 on the dyno [Re: hugo] #3136258
04/07/23 04:27 PM
04/07/23 04:27 PM
For my combo, 4.56 and a 33 inch tall tire worked, went through at 7400. If you race only 1/8 mile, AND run a powerglide, you can go higher ratio, but i wouldn't recomend it with a 2.45 low torqueflite.
Re: 528 on the dyno [Re: 440Jim] #3136260
04/07/23 04:31 PM
04/07/23 04:31 PM
Indy 440-1 heads
13.6 CR
4.500" bore?
Cam duration, LSA
Jim, cam is a 1625b/ 1634b, .501 int lobe, .500 ex lobe? Duration 283/286/110+4 for a 106 install. 64.5 degrees overlap with a lash setting of . 026, which IMHO must reduce the actrual running duration a bit comparead to more modern low lash designs? With the shorter exhaust duration, i wonder if that is better with 13.6 compression, versus say 15/1? With that early install, it pulled very well all the way to 7200 rpm. Never pulled it higher.
One more note, that 1625b intake is a radical lobe, as i had a cam ground with it way back in 2005 and was told it was used in superstock motors then.
Re: 528 on the dyno [Re: hugo] #3136410
04/08/23 08:49 AM
04/08/23 08:49 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
I am running a 727. First gear ratio is 2.28, not the stock 2.45 ratio.
4.56 rear gear
Tires are Hoosier 32x13.5w stiff sidewall.
On 1/4 mile, I’ll see 7800+ on good air but haven’t been on 1/4 mile in quite some time.
My shift points are 7150 1-2 and 7300 2-3. That’s data right from my ignition.
Re: 528 on the dyno [Re: gregsdart] #3137897
04/14/23 08:05 AM
04/14/23 08:05 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I just assume this is a repost of one of the more recent 440-1 builds? Either way #'s look good to me NICE BUILD!
Re: 528 on the dyno [Re: HardcoreB] #3137899
04/14/23 08:34 AM
04/14/23 08:34 AM
a friend of mines engine. New iron block, 4.15 x 4.500 528 cubes. c14+. The heads were done by R&R, cam was designed by Todd Goodwin years ago.
Re: 528 on the dyno [Re: gregsdart] #3138056
04/14/23 09:16 PM
04/14/23 09:16 PM
PA
moparacer Offline
moparacer  Offline
PA
I run 88s in my car with a glide. I run a tall Phoenix PH338 that is 107 roll out. Shift at 6900 and cross the 1/8 around 72-7300.
She would be singing at the 1/4 mile mark I bet.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
