Re: 528 on the dyno
[Re: 440Jim]
#3134969
04/04/23 08:16 AM
04/04/23 08:16 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
528 CID Looks like it made about 872hp at 7100 rpm Indy 440-1 heads 13.6 CR 0.800" lift intake valve
Do you have any more specs? 4.500" bore? Cam duration, LSA Bore 4.500 rings . 9mm. No vacuum pump. C12fuel. Harland Sharp 1.6 rockers, 3/8 smith pusheods. Cam is over 280 on the intake, Tim was going to call me with full specs. Originally a Godwin spec'd design for 440-1 heads on a 497 i believe.
Re: 528 on the dyno
[Re: 71Demon528]
#3136148
04/07/23 09:31 AM
04/07/23 09:31 AM
Posts: 403 Laredo, Texas USA
hugo
Laredo, Texas USA
I have no idea what my 528 with -1s makes on the Dyno, but I know it runs really in my car and I love the combo. My car weighs 2825 race ready last year. I added some tubing to the car over the winter so I don’t know how much weight I added but probably 10 lbs or so. I just ran my fastest pass last weekend. 5.48 at 124mph. That was spinning. The following pass was an elimination pass, car hooked up great but I had to lift due to being ahead. Incrementals show I was on a 5.44-5.45 pass. Engine built by Tim Bowman at Bowman Performance. What transmission and rear gears are you using?
Re: 528 on the dyno
[Re: hugo]
#3136258
04/07/23 04:27 PM
04/07/23 04:27 PM
gregsdart
For my combo, 4.56 and a 33 inch tall tire worked, went through at 7400. If you race only 1/8 mile, AND run a powerglide, you can go higher ratio, but i wouldn't recomend it with a 2.45 low torqueflite.
Re: 528 on the dyno
[Re: 440Jim]
#3136260
04/07/23 04:31 PM
04/07/23 04:31 PM
gregsdart
528 CID Looks like it made about 872hp at 7100 rpm, 723 ft-lbs at 5600 rpm Indy 440-1 heads 13.6 CR 0.800" lift intake valve
Do you have any more specs? 4.500" bore? Cam duration, LSA Jim, cam is a 1625b/ 1634b, .501 int lobe, .500 ex lobe? Duration 283/286/110+4 for a 106 install. 64.5 degrees overlap with a lash setting of . 026, which IMHO must reduce the actrual running duration a bit comparead to more modern low lash designs? With the shorter exhaust duration, i wonder if that is better with 13.6 compression, versus say 15/1? With that early install, it pulled very well all the way to 7200 rpm. Never pulled it higher. One more note, that 1625b intake is a radical lobe, as i had a cam ground with it way back in 2005 and was told it was used in superstock motors then.
Re: 528 on the dyno
[Re: HardcoreB]
#3137899
04/14/23 08:34 AM
04/14/23 08:34 AM
gregsdart
I just assume this is a repost of one of the more recent 440-1 builds? Either way #'s look good to me NICE BUILD! a friend of mines engine. New iron block, 4.15 x 4.500 528 cubes. c14+. The heads were done by R&R, cam was designed by Todd Goodwin years ago.
Re: 528 on the dyno
[Re: gregsdart]
#3138056
04/14/23 09:16 PM
04/14/23 09:16 PM
Posts: 2,515 PA
moparacer
PA
For my combo, 4.56 and a 33 inch tall tire worked, went through at 7400. If you race only 1/8 mile, AND run a powerglide, you can go higher ratio, but i wouldn't recomend it with a 2.45 low torqueflite. I run 88s in my car with a glide. I run a tall Phoenix PH338 that is 107 roll out. Shift at 6900 and cross the 1/8 around 72-7300. She would be singing at the 1/4 mile mark I bet.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
