AVS rods and jets? #3127736
03/09/23 09:35 AM
03/09/23 09:35 AM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I need 120-489 primary main fuel jets and metering rods for a 4401S. Carter AVS carburator.Help me out if you can Thanks my64bel@yahoo.com 406-539-6678
Re: AVS rods and jets? [Re: MO_PA] #3127797
03/09/23 01:20 PM
03/09/23 01:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you're looking for new jets and rods they aren't available. chyrsler had a unique primary jet and 3 step metering rod. you can use edelbrock jets and rods but you'll need the edelbrock step-up piston cover.
Re: AVS rods and jets? [Re: lewtot184] #3127811
03/09/23 01:51 PM
03/09/23 01:51 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thank You,
I know the Edelbrock route but I plan to go with the three step rods and the tall jets.
Re: AVS rods and jets? [Re: MO_PA] #3127854
03/09/23 03:43 PM
03/09/23 03:43 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I bought a few last year. There isn’t a particular source. Just have to watch and wait. The carb guy in Missouri has an attitude and went on a diatribe about mopars being dirty running cars. Has a machine he says is the original carter one and will cut you a new set. For 220 bucks that is. I declined.
I want my fair share
Re: AVS rods and jets? [Re: MO_PA] #3127960
03/09/23 10:35 PM
03/09/23 10:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Sorry but is the jet # 489 and the rod # 120? I have to check my stash tomorrow beer
Re: AVS rods and jets? [Re: MO_PA] #3128009
03/10/23 12:57 AM
03/10/23 12:57 AM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: AVS rods and jets? [Re: lilcuda] #3128010
03/10/23 01:00 AM
03/10/23 01:00 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Originally Posted by lilcuda
That guy has a wealth of knowledge and is worth a call. I couldn’t think of the place so thanks for posting.
Re: AVS rods and jets? [Re: TJP] #3128036
03/10/23 09:28 AM
03/10/23 09:28 AM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
The jet number is 489, carter number is 120-489, 489 is stamped on the jet,
0.089 bore, this is the tall jet USED ONLY WITH THE THREE STEP METERING ROD.
I hope you have these jets, If you have the metering rods it will be a plus. Thanks!!
Re: AVS rods and jets? [Re: MO_PA] #3128093
03/10/23 11:58 AM
03/10/23 11:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You might have to buy a carb for parts .
Re: AVS rods and jets? [Re: JohnRR] #3128116
03/10/23 12:42 PM
03/10/23 12:42 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I stripped 4 other carbs, either the jets were missing, drilled oversize, or wrong...I have two identical carbs,
one is done, the other is missing the correct jets. These carbs will be on a cross ram intake for my max wedge 440cid engine
Re: AVS rods and jets? [Re: MO_PA] #3128119
03/10/23 12:44 PM
03/10/23 12:44 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think I might have them. I'll have to check out in the shop.
Re: AVS rods and jets? [Re: GomangoCuda] #3128122
03/10/23 12:46 PM
03/10/23 12:46 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks GoMango
Re: AVS rods and jets? [Re: MO_PA] #3128135
03/10/23 01:17 PM
03/10/23 01:17 PM
GomangoCuda Offline
GomangoCuda  Offline
I have the jets. What size rods are you looking for?
Re: AVS rods and jets? [Re: GomangoCuda] #3128144
03/10/23 01:34 PM
03/10/23 01:34 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Just checked with my right hand man, I don't need the rods I have new old stock rods.
How do we proceed from here. I do want the jets. My wife has PayPal or I can send
you a check or money order. What are you asking for the jets?
Re: AVS rods and jets? [Re: MO_PA] #3128214
03/10/23 05:38 PM
03/10/23 05:38 PM
GomangoCuda Offline
GomangoCuda  Offline
Instant message sent.
Re: AVS rods and jets? [Re: MO_PA] #3128272
03/10/23 10:29 PM
03/10/23 10:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I apologize as it was a busy day and I completely blew it off spank
I do have quite a few parts and a few carbs if anyone else is looking but little time so patience may be required frown
Again I apologize beer
Re: AVS rods and jets? [Re: TJP] #3128526
03/11/23 05:48 PM
03/11/23 05:48 PM
moparx Offline
moparx  Offline
thermo-quads are [kind of] like the AVS carbs, in that if a guy needs jets and rods, you need to search them out.
i always recommend looking for crusty carbs at the swaps, where guys are just cleaning out their stashes, and you might possibly get lucky and find the carbs and or parts, you need.
will not always happen, but you never know.
just my experience in life. your mileage will vary.
beer
Re: AVS rods and jets? [Re: moparx] #3128558
03/11/23 07:50 PM
03/11/23 07:50 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
A fellow Moparts man has the correct parts that I need, We have made a deal, he and I will close the deal.
Thanks to all of you that offered help!!
