Re: AVS rods and jets?
[Re: MO_PA]
#3127854
03/09/23 03:43 PM
03/09/23 03:43 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I bought a few last year. There isn’t a particular source. Just have to watch and wait. The carb guy in Missouri has an attitude and went on a diatribe about mopars being dirty running cars. Has a machine he says is the original carter one and will cut you a new set. For 220 bucks that is. I declined.
I want my fair share
[Re: lilcuda]
#3128010
03/10/23 01:00 AM
03/10/23 01:00 AM
SomeCarGuy
That guy has a wealth of knowledge and is worth a call. I couldn’t think of the place so thanks for posting.
[Re: MO_PA]
#3128093
03/10/23 11:58 AM
03/10/23 11:58 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The jet number is 489, carter number is 120-489, 489 is stamped on the jet, 0.089 bore, this is the tall jet USED ONLY WITH THE THREE STEP METERING ROD. I hope you have these jets, If you have the metering rods it will be a plus. Thanks!! You might have to buy a carb for parts .
[Re: JohnRR]
#3128116
03/10/23 12:42 PM
03/10/23 12:42 PM
Posts: 1,791 Big Sky Country
MO_PA
Big Sky Country
I stripped 4 other carbs, either the jets were missing, drilled oversize, or wrong...I have two identical carbs, one is done, the other is missing the correct jets. These carbs will be on a cross ram intake for my max wedge 440cid engine
[Re: MO_PA]
#3128214
03/10/23 05:38 PM
03/10/23 05:38 PM
Posts: 4,731 Moved to N.E. Tennessee
GomangoCuda
Just checked with my right hand man, I don't need the rods I have new old stock rods. How do we proceed from here. I do want the jets. My wife has PayPal or I can send you a check or money order. What are you asking for the jets? Instant message sent.
[Re: TJP]
#3128526
03/11/23 05:48 PM
03/11/23 05:48 PM
Posts: 19,464 north of coder
moparx
thermo-quads are [kind of] like the AVS carbs, in that if a guy needs jets and rods, you need to search them out. i always recommend looking for crusty carbs at the swaps, where guys are just cleaning out their stashes, and you might possibly get lucky and find the carbs and or parts, you need. will not always happen, but you never know. just my experience in life. your mileage will vary.
