Re: Rottella T
[Re: patrick]
#312714
05/11/09 07:23 PM
05/11/09 07:23 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Slightly OT ....
Anyone here know the designation on any oil container that indicates heavy zinc content?
I have got a couple of motors going together and will be using NON-roller cam.
I would use a roller but since the roller lifters I have heard of here and elsewhere are not reliable .....I will pass on that idea.
hmm...roller lifters have only been in small block mopars for 24 years now......the OEM hydraulic rollers are VERY reliable.
Hey patrick .... take a look at my 3:25am post.
Re: Rottella T
[Re: dOrk !]
#312715
05/12/09 08:46 AM
05/12/09 08:46 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Slightly OT ....
BB app is a little different animal. also, I think most of the problems seen are with solid rollers, very aggressive ramps, and lots of spring pressure. a hydraulic roller lifter from a reputable company (comp, crower, etc), with a not-quite so aggressive lobe so you can keep the spring pressures down a bit I think would live fine. I'd be more concerned in a BB app about the bronze dist. drive gear from a longevity standpoint. although I thought crane used to make hydraulic street rollers with a pressed on cast gear so you didn't need to run a bronze dist drive gear.
Re: Rottella T
[Re: Pacnorthcuda]
#312716
05/13/09 05:33 PM
05/13/09 05:33 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Just got 2 One gallon jugs of Rotella T 15w-40 from my local autozone. They had 2 different ones. I got the older(?) Not-as-emmisions-friendly jugs for $13.49 each. Mine reads: Meets API SERVICE CJ-4, CI-4PLUS, CH-4, CG-4, CF-4, CF/SM, SL, SJ. Hope I got the right one or as they say, the lesser of two evils.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Rottella T
[Re: Hoof Hearted]
#312717
05/13/09 10:05 PM
05/13/09 10:05 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
If the API specs begins with CJ-4, then you got the newer CJ-4 and not the earlier CI-4+
As it goes, they tell us the CJ-4 is backwards compatible with the previous specs: CI-4PLUS, CH-4, CG-4, CF-4, CF/SM, SL, SJ.
Of course we've heard the term backwards compatible before when the API (SM) spec came out, and we know how that one panned out.
