Page 3 of 3 1 2 3
Re: Rottella T [Re: patrick] #312714
05/11/09 07:23 PM
05/11/09 07:23 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Slightly OT ....
Anyone here know the designation on any oil container that indicates heavy zinc content?
I have got a couple of motors going together and will be using NON-roller cam.
I would use a roller but since the roller lifters I have heard of here and elsewhere are not reliable .....I will pass on that idea.
hmm...roller lifters have only been in small block mopars for 24 years now......the OEM hydraulic rollers are VERY reliable.
Hey patrick .... take a look at my 3:25am post.
Re: Rottella T [Re: dOrk !] #312715
05/12/09 08:46 AM
05/12/09 08:46 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Slightly OT ....
BB app is a little different animal. also, I think most of the problems seen are with solid rollers, very aggressive ramps, and lots of spring pressure. a hydraulic roller lifter from a reputable company (comp, crower, etc), with a not-quite so aggressive lobe so you can keep the spring pressures down a bit I think would live fine. I'd be more concerned in a BB app about the bronze dist. drive gear from a longevity standpoint. although I thought crane used to make hydraulic street rollers with a pressed on cast gear so you didn't need to run a bronze dist drive gear.
2017 Grand Cherokee Overland
Re: Rottella T [Re: Pacnorthcuda] #312716
05/13/09 05:33 PM
05/13/09 05:33 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Just got 2 One gallon jugs of Rotella T 15w-40 from my local autozone. They had 2 different ones.
I got the older(?) Not-as-emmisions-friendly jugs for $13.49 each.
Mine reads: Meets API SERVICE CJ-4, CI-4PLUS, CH-4, CG-4, CF-4, CF/SM, SL, SJ.
Hope I got the right one or as they say, the lesser of two evils.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Rottella T [Re: Hoof Hearted] #312717
05/13/09 10:05 PM
05/13/09 10:05 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
If the API specs begins with CJ-4, then you got the newer CJ-4 and not the earlier CI-4+
As it goes, they tell us the CJ-4 is backwards compatible with the previous specs: CI-4PLUS, CH-4, CG-4, CF-4, CF/SM, SL, SJ.
Of course we've heard the term backwards compatible before when the API (SM) spec came out, and we know how that one panned out.
Re: Rottella T [Re: CompSyn] #312718
05/13/09 10:35 PM
05/13/09 10:35 PM
grant louisiana
mayhem148 Offline
mayhem148  Offline
grant louisiana
i work on industrial engines offshore for a living. everymonth we send in oil samples for all the equipment that i work on offshore. the oils we use were rotella t and mysella 40 low ash and now pegusas 805. (all from shell.) the samples are sent in to tell us when we need to change the oil. (money saving thing so we dont waste oil by changing to much.) with the mysella and pegasus we change oil and filter every 3000 hours which pretty much adds up to 3 months. with the rotella i changed the oil annually. they would suggest changing the filters but thats it. this is on engines that displace 9390 cubic inches that compress 10 million cubic feet of gas everyday and run 24 hours a day. all they do is work under extreme loads. now i am sorry but after seeing that with my own eyes i will run rotella in everything that i own. the only oil that i have even seen to impress me more than that is royal purple. they have this display thing that grinds 2 pieces of metal together. with regular oil the metal would smoke and grind away. they put one drop of purple mixed with the other and put it on the grinder and it wouldnt even smoke. i am sure you can find it on youtube. anyway i just thought i give my own opinion and experience on the subject.
Re: Rottella T [Re: RapidRobert] #312719
05/13/09 11:17 PM
05/13/09 11:17 PM
NC
DARTSPORT340 Offline
super gas
super gas
NC
I used rottella 30 in all my stuff. When I have a flat tappet car I use rottella with a bottle of GM EOS. My engine builder swears by the stuff.
Page 3 of 3 1 2 3
