Head gasket for 572 Hemi #3124191
02/24/23 10:53 AM
02/24/23 10:53 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What head gaskets you guys using on your 572 Hemi's? What bore and thickness is commonly used?
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124194
02/24/23 11:16 AM
02/24/23 11:16 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Cometic, and mine has to be larger than the bore due to the big intake valves. I think I run a 4.530 on a 4.500 bore, but it might be smaller. Thickness is anywhere from .027 to .041 for me.
Re: Head gasket for 572 Hemi [Re: Dragula] #3124195
02/24/23 11:19 AM
02/24/23 11:19 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, i didnt know you could get the bore that close. I thought 4.500 then 4.600. Thats great, thanks
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124210
02/24/23 12:56 PM
02/24/23 12:56 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Which block? Some blocks may need different head gaskets. For example, BMP blocks require a different gasket then a KB or an old Mega block.
Re: Head gasket for 572 Hemi [Re: blowndart] #3124225
02/24/23 01:33 PM
02/24/23 01:33 PM
Mt Morris Michigan
Mt Morris Michigan
BM aluminum block with stage v heads.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124230
02/24/23 01:55 PM
02/24/23 01:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Cometic here also. A 4.530 x 031 on my engine. Making any big horsepower or nitrous/boosted pay for extra for their newer MLX gaskets.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124233
02/24/23 01:57 PM
02/24/23 01:57 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Cometic make a head gasket specific to a BMP block. You may want to contact the company that you bought the block from, or Bill Mitchell directly, for the right head gasket. I have a BMP block as well that I haven't put together yet.
Re: Head gasket for 572 Hemi [Re: blowndart] #3124418
02/25/23 01:14 AM
02/25/23 01:14 AM
Mt Morris Michigan
Mt Morris Michigan
Glad i asked. Thanks
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124452
02/25/23 10:49 AM
02/25/23 10:49 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My 605 is zero decked, I run a .052 cosmetic. I tried a .042 and had very light contact once on a dyno mishap.
Re: Head gasket for 572 Hemi [Re: quickd100] #3124455
02/25/23 10:55 AM
02/25/23 10:55 AM
Mt Morris Michigan
Mt Morris Michigan
Looks like i'm about .002-.003 + on the deck. With a 12:1 piston.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3124976
02/27/23 10:04 AM
02/27/23 10:04 AM
an8sec70cuda Offline
I use a .040" thick Cometic MLS gasket. Pretty sure it's 4.53" bore.
The KB block has it's own gasket also...may be the same as the BMP, not sure. The steam holes are relocated outward.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Head gasket for 572 Hemi [Re: an8sec70cuda] #3124982
02/27/23 10:27 AM
02/27/23 10:27 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I asked Bill Mitchell about head gaskets for a Hemi and he says it takes stock gaskets. I didn't ask about a wedge but I assume it's the same.
2011 Drag Pak Challenger
Re: Head gasket for 572 Hemi [Re: rickseeman] #3125064
02/27/23 04:36 PM
02/27/23 04:36 PM
the first K-B street Hemi motor I built had to have special head gaskets made due to it being a dry sleeve block, I ended finding out that the race KB water blocks take different head gaskets depending on which version the block is, IE a stage 1 block doesn't use the same head gasket as a stage 4 block does scope
Re: Head gasket for 572 Hemi [Re: Cab_Burge] #3125212
02/28/23 10:07 AM
02/28/23 10:07 AM
Mt Morris Michigan
Mt Morris Michigan
I laid my old cometics from my wedge on the BM block and found the wedge gasket is in the way of the inner head bolt holes.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3125253
02/28/23 12:23 PM
02/28/23 12:23 PM
Mt Morris Michigan
Mt Morris Michigan
This thing is a beast on the stand.
B6D024AF-D59D-4607-AD9E-CC62BB064119.jpegFDABD29B-707B-4A9B-A779-4FBCFA8A0637.jpeg9D4C18C5-97BB-4A73-A22E-BED493E56899.jpeg
Re: Head gasket for 572 Hemi [Re: mopar dave] #3125256
02/28/23 12:27 PM
02/28/23 12:27 PM
Mt Morris Michigan
Mt Morris Michigan
I like how the ports are straight in from the plenum.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3125258
02/28/23 12:29 PM
02/28/23 12:29 PM
Mt Morris Michigan
Mt Morris Michigan
These stage v heads show 442@.700 lift intake flow. The ports look huge.
Re: Head gasket for 572 Hemi [Re: mopar dave] #3125284
02/28/23 01:30 PM
02/28/23 01:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks like a nice piece so far. If I remember my heads were 486 at .800.
Re: Head gasket for 572 Hemi [Re: 6PKRTSE] #3125313
02/28/23 02:31 PM
02/28/23 02:31 PM
Mt Morris Michigan
Mt Morris Michigan
Wow, that is a lot of air. My numbers are 460@.800 and 471@.850. My lift after lash is .700
Re: Head gasket for 572 Hemi [Re: mopar dave] #3125343
02/28/23 03:44 PM
02/28/23 03:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Oops, typo 468.
