the first K-B street Hemi motor I built had to have special head gaskets made due to it being a dry sleeve block, I ended finding out that the race KB water blocks take different head gaskets depending on which version the block is, IE a stage 1 block doesn't use the same head gasket as a stage 4 block does scope
