Re: 80s truck hydraulic clutch questions
[Re: poorboy]
#3121056
02/12/23 11:41 PM
02/12/23 11:41 PM
Posts: 2,251 ILLINOIS
volaredon
ILLINOIS
There is no "Z" bar or Z bar linkage with the hydraulic clutch.
The hydraulic system replaces the Z bar and its linkage with the master cylinder attached to the plastic tubing that goes to the slave cylinder. The slave cylinder bolts to the bell. The only mechanical connections in a hydraulic clutch is the rod from the pedal to the master cylinder and the rod from the slave to the clutch fork inside of the bell. The fork connects directly to the throw out bearing, as it would with a complete mechanical linkage. Yes I'm aware of all of this. I have the mechanical linkage that goes with it, I was wanting to eliminate that and switch it over. I wasn't sure I wanted to use the factory hydraulic setup to accomplish that or not. I have "most" of that as well. Just lacking the bracket that holds the master at the firewall and maybe the right clutch fork. Looking at the reply above yours, that showed links to the pedal for mechanical linkage and the one for the factory hydraulic, I can modify my pedal to look like the one he shows as being for the hydraulic clutch "no problem" I just didn't know there was a difference between pedals used with either setup.
[Re: volaredon]
#3122164
02/16/23 08:41 PM
02/16/23 08:41 PM
Guitar Jones
The earlier trucks before the hydraulic clutch was in production don't have the holes drilled into the steering column/dash brace to mount the bracket. I did my 74 with a Kobalt cordless drill and a unibit, but I had the dash, steering column and wiring harnesses out of the truck. You will also need to relocate the bulkhead connector.
