Early B-body mini tub ???? #3111932
01/14/23 06:13 PM
01/14/23 06:13 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Has anyone Mini Tubbed a 64 Dodge B-body? My? is how do the supports for the torsion springs and the hinges for the trunk lid work out, will they need bracing while the tub is out before I reinstall it and reattach them to the tub? I mean while the inner tub is out will they just stay put only attached at the top?
Re: Early B-body mini tub ???? [Re: fuseable] #3112024
01/15/23 12:00 AM
01/15/23 12:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No bracing needed. Mt 64 is fully tubbed. Stcock hinges and toesion springs. It's been done 12 years with no ill effects.
Doug
Re: Early B-body mini tub ???? [Re: dvw] #3112031
01/15/23 12:52 AM
01/15/23 12:52 AM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Maybe I am not presenting the question right. The question is when you remove the tub, the inner tub, will the trunk lid springs, and hinge points stay in place with no lower support until you get the new tub installed and reattach the trunk lid springs, and hinge points back to the relocated tub?
Re: Early B-body mini tub ???? [Re: fuseable] #3112056
01/15/23 09:29 AM
01/15/23 09:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I took the springs and deck lid off. In fact the tubs couldn't be slid into place with the hinge brackets in place. The spot welds were drilled out. Tubs installed and brackets were rewelded. When I've mini tubbed we've still removed the deck lid and springs.
Doug
Re: Early B-body mini tub ???? [Re: dvw] #3112071
01/15/23 10:21 AM
01/15/23 10:21 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine is an E Body, but same concept as mentioned above. My trunk hinges and bracing were welded back in place after mini- tubbed. In stock locations just had the be trimmed to follow the new tubs contour.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Early B-body mini tub ???? [Re: 6PKRTSE] #3112076
01/15/23 10:38 AM
01/15/23 10:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Yes. BUT, life is easier if you 1) remove the trunk and 2) back off the tension or even remove those torsion bars during the minitub process.
Re: Early B-body mini tub ???? [Re: Stanton] #3112121
01/15/23 12:50 PM
01/15/23 12:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think the OP's question is whether he needs to brace the structure while he's working ?
There's a lot of structure already, so if the back glass, surrounding structure, and quarter panels are intact, bracing isn't necessarily required.
Easy enough to verify - and correct if necessary - by taking before & during measurements.
One could place a strut under the package tray/trunk lid lip area to the trunk floor if need be.
That could even be a wood 2x4 with a tight fit.
Re: Early B-body mini tub ???? [Re: topside] #3112129
01/15/23 01:23 PM
01/15/23 01:23 PM
Midwest
fuseable Offline OP
fuseable  Offline OP
Midwest
Yes that is the ?. Thanks for the reply
Re: Early B-body mini tub ???? [Re: fuseable] #3112185
01/15/23 04:57 PM
01/15/23 04:57 PM
AndyF Online content
AndyF  Online Content
Here is a short video that shows some of the stuff on my '65 Coronet: https://youtu.be/zWV8W3Pl4yg
Re: Early B-body mini tub ???? [Re: fuseable] #3112317
01/15/23 11:28 PM
01/15/23 11:28 PM
I removed and replaced all of the rear inner tubs on my 1963 Plymouth Belvedere a long time ago, I bought and used a rea tub kit from Alston's Chassis works and made it fit up
I'm not a good fabricator or welder, I used pop rivets where needed and seal the upper tub to the 1.4 panels with seam sealer, I think it was some sort of seam sealer confused
The inner upright had a pinch seam that the upper tub fit into and pushed it together, I think it was called a "Pittsburgh" seam. work shruggy
I ended up using duct tape on the inside of the upper and outer seams to keep smoke out from the burnouts. whistling That worked upshruggy
