Early B-body mini tub ????
#3111932
01/14/23 06:13 PM
01/14/23 06:13 PM
Posts: 766 Midwest
fuseable
Midwest
Has anyone Mini Tubbed a 64 Dodge B-body? My? is how do the supports for the torsion springs and the hinges for the trunk lid work out, will they need bracing while the tub is out before I reinstall it and reattach them to the tub? I mean while the inner tub is out will they just stay put only attached at the top? Thanks
Re: Early B-body mini tub ????
[Re: fuseable]
#3112024
01/15/23 12:00 AM
01/15/23 12:00 AM
Posts: 9,835 MI, usa
dvw
MI, usa
No bracing needed. Mt 64 is fully tubbed. Stcock hinges and toesion springs. It's been done 12 years with no ill effects. Doug
[Re: dvw]
#3112031
01/15/23 12:52 AM
01/15/23 12:52 AM
Posts: 766 Midwest
fuseable
Midwest
Maybe I am not presenting the question right. The question is when you remove the tub, the inner tub, will the trunk lid springs, and hinge points stay in place with no lower support until you get the new tub installed and reattach the trunk lid springs, and hinge points back to the relocated tub?
[Re: dvw]
#3112071
01/15/23 10:21 AM
01/15/23 10:21 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Mine is an E Body, but same concept as mentioned above. My trunk hinges and bracing were welded back in place after mini- tubbed. In stock locations just had the be trimmed to follow the new tubs contour.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3112076
01/15/23 10:38 AM
01/15/23 10:38 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
will the trunk lid springs, and hinge points stay in place with no lower support until you get the new tub installed and reattach the trunk lid springs, and hinge points back to the relocated tub? Yes. BUT, life is easier if you 1) remove the trunk and 2) back off the tension or even remove those torsion bars during the minitub process.
[Re: topside]
#3112129
01/15/23 01:23 PM
01/15/23 01:23 PM
Posts: 766 Midwest
fuseable
Midwest
I think the OP's question is whether he needs to brace the structure while he's working ? There's a lot of structure already, so if the back glass, surrounding structure, and quarter panels are intact, bracing isn't necessarily required. Easy enough to verify - and correct if necessary - by taking before & during measurements. One could place a strut under the package tray/trunk lid lip area to the trunk floor if need be. That could even be a wood 2x4 with a tight fit. Yes that is the ?. Thanks for the reply
[Re: fuseable]
#3112185
01/15/23 04:57 PM
01/15/23 04:57 PM
Posts: 31,033 Oregon
AndyF
Has anyone Mini Tubbed a 64 Dodge B-body? My? is how do the supports for the torsion springs and the hinges for the trunk lid work out, will they need bracing while the tub is out before I reinstall it and reattach them to the tub? I mean while the inner tub is out will they just stay put only attached at the top? Thanks Here is a short video that shows some of the stuff on my '65 Coronet: https://youtu.be/zWV8W3Pl4yg
