Thinking about rebuildind a 727 Trans #310929
05/07/09 12:51 PM
05/07/09 12:51 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
but I've never done that before.I've watched a few times as someone else did the rebuild and redone a few engines in my time.is this a difficult task for a novice?bad idea? I have a few good articles on all the tweaks but if anyone has a link to a good article on rebuilding a 727 could you help a guy out and post a link?
the trans in question is a 73 big block trans and I also have a 68/69 smallblock trans I could use for parts if need be,Thanks!
Re: Thinking about rebuildind a 727 Trans [Re: stinger] #310930
05/07/09 02:15 PM
05/07/09 02:15 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Some of the internal parts are going to be different between the 2 trans you have. Start by getting the 727 hand book by Carl Monroe.
They are not hard to do.
Re: Thinking about rebuildind a 727 Trans [Re: WILD BILL] #310931
05/07/09 02:17 PM
05/07/09 02:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The Munroe book is gold. 10-15 bucks on ebay.
Re: Thinking about rebuildind a 727 Trans [Re: DaytonaTurbo] #310932
05/07/09 04:47 PM
05/07/09 04:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ATSG video..........
Tony
70 AARCuda Vitamin C
Re: Thinking about rebuildind a 727 Trans [Re: DaytonaTurbo] #310933
05/07/09 10:01 PM
05/07/09 10:01 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Re: Thinking about rebuildind a 727 Trans [Re: mopowers] #310934
05/07/09 11:33 PM
05/07/09 11:33 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Thanks guys,going to order a copy and give it a go!
Re: Thinking about rebuildind a 727 Trans [Re: stinger] #310935
05/08/09 08:17 AM
05/08/09 08:17 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
You may want to check out this item on the E Bay.
Item number: 350198259349 DVD on 727 rebuild.
I don't know what its like maybe good maybe not just letting you know it's out there.
Maynard
Re: Thinking about rebuildind a 727 Trans [Re: WILD BILL] #310936
05/08/09 10:28 AM
05/08/09 10:28 AM
Az
Crizila Offline
Crizila  Offline
Az
- if you are doing a stock or minor improvements ( valve body mods / additional clutch discs )rebuild. If you are putting it behind 700 + HP or so, I would suggest someone like CRT build it for you.
Fastest 300
Re: Thinking about rebuildind a 727 Trans [Re: DartGTS] #310937
05/08/09 12:18 PM
05/08/09 12:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Hello:
Maynard
I have the VHS version of that...excellent...it will walk you thru the rebuilding of a 727...you can stop it and rewind it ...the book is a great information source...but watching someone rebuild the trans is priceless.
Tony
Re: Thinking about rebuildind a 727 Trans [Re: Crizila] #310938
05/08/09 01:40 PM
05/08/09 01:40 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
just for my ice cream getter,not a race car.I do want it beefed up a little to stand up to a warmed up 440.
thanks for the heads up on the e bay item,I'll check into that.I just think it would be fun to build a trans as long as it works when I'm done and save a little coin to use on other parts I need.
Re: Thinking about rebuildind a 727 Trans [Re: stinger] #310939
05/08/09 09:13 PM
05/08/09 09:13 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Couple of pieces of advise when I built my first 727:
1) Cleaniness can not be over emphasized!
2) Have a FSM handy - good info for troubleshooting/etc. and additional pictures and how to make some needed tools that the Monroe book doesn't cover (but the Monroe book is mandatory IMHO).
3) Tranny Hydralic Pressure gauges - purchase or rent. If you have any shifting/etc. issues after the build, this tool and the FSM will point you to exactly where the problem was.
In my first build, it all went smooth. Car didn't want to shift out of first... put on the gauges, consulted the FSM, and it pointed to the govenor... I pulled it, and found a hair that was hanging up the little internal piston. Cleaned it, and viola!
IMHO, the biggest PITA is removing/installing the tail shaft snap ring.
It's installed in my son's 77 Fury - a heavy car with a warmed up 400. By son has bit the crap out of that car, and the tranny has functioned flawlessly for about 30,000 miles now. I am impressed.
Mods I made, according to advise from this forum:
1)Bolt in Sprang (probably not necessary for street car)
2)High Perf Master rebuild kit (new gaskets, seals, sealing rings, Red Eagle friction clutch kit, Kolene Steels).
3)Dacron filter
4) 4.2 Lever & Heavy Duty Band Strut
5) TransGo TF-2 Kit setup on Hot Rod Setting.
I spent about $350 on everything.
Sources for parts:
Transmission Center
BulkPart
CRT
Good luck and let us know how it goes!
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: Thinking about rebuildind a 727 Trans [Re: G_T] #310940
05/09/09 11:15 AM
05/09/09 11:15 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
great info GT! thanks,it helps alot.
Re: Thinking about rebuildind a 727 Trans [Re: stinger] #310941
05/09/09 11:47 AM
05/09/09 11:47 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I found this link an interesting read, he did it on a 64 trans but it still applies to rebuilding a 727. Ron...
click on the highlighted areas for pictures...
http://www.yetanotherdomain.org/64dodge/transmission/rebuildsteps.html
Re: Thinking about rebuildind a 727 Trans [Re: Mopar Ron] #310942
05/09/09 08:41 PM
05/09/09 08:41 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Thanks Ron,great article to read.it looks like something I can do with the help of the Monroe book and a little time.
Re: Thinking about rebuildind a 727 Trans [Re: stinger] #310943
05/10/09 10:22 AM
05/10/09 10:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I live in Waterford and have the book if you would like to borrow it. I've beeen doing 727s for 30 years if you have any questions. I've taught many to do them. Basic rebuilds and hop ups are pretty easy. Any questions shoot me a PM
Doug
