Some of the internal parts are going to be different between the 2 trans you have. Start by getting the 727 hand book by Carl Monroe.
They are not hard to do.
- if you are doing a stock or minor improvements ( valve body mods / additional clutch discs )rebuild. If you are putting it behind 700 + HP or so, I would suggest someone like CRT build it for you.
Fastest 300
