Big block A body and power steering #3106752
12/30/22 06:58 PM
12/30/22 06:58 PM
Ontario Canada
Bennoel 10 Offline OP
Ontario Canada
Was having a conversation with an old friend who asked "was p/s available in 67 to 69 GTS with a big block". Never owning one myself I wasn't 100% sure. My response was I believe so. The only big block A body that it wasn't available with was the "M" code A body. Also no 4spd or column shift with the M code iirc.
What say the Moparts community ???
Thanks.
Re: Big block A body and power steering [Re: Bennoel 10] #3106770
12/30/22 07:58 PM
12/30/22 07:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Yes, they could have PS,
Re: Big block A body and power steering [Re: BSB67] #3106851
12/31/22 01:32 AM
12/31/22 01:32 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 69 383 4-speed GTS has factory power steering. It came in late 68, another reason the exhaust manifolds were redesigned... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Big block A body and power steering [Re: Rhinodart] #3106854
12/31/22 02:09 AM
12/31/22 02:09 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
What about this statement by the OP ?
Quote
Mike
Re: Big block A body and power steering [Re: A12] #3106855
12/31/22 02:18 AM
12/31/22 02:18 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
The reason for no 4-speed for the 440 M-code, was at the time no DANA narrow enough for the A-Body. Ha, that didn't stop a lot of M-code owners from cutting the floor and putting in a 4-speed with the stock 8-3/4, including the owner of my Dart 440 M-code GTS. I have an auto floor patch to fix that fortunately.
Re: Big block A body and power steering [Re: A12] #3106856
12/31/22 02:34 AM
12/31/22 02:34 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
My '68 383 GTS had PS. All original car. up
Re: Big block A body and power steering [Re: bobby66] #3106966
12/31/22 02:32 PM
12/31/22 02:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
IIRC, the early 383 A-bodies couldn't get PS, but as Rhino says, that was addressed later.
Pretty sure a buddy's 383/AT '69 Dart GTS had PS, but I last saw & drove it about 30 years ago.
Also IIRC no PS on the 440 A-bodies, due to the larger mass of the RB; likely an interference near the battery tray or fitting the larger PS box.
While the Hemi A-body drag cars got Danas, they also had offset wheels, and in the obvious case of the Darts, radiused openings to fit the resulting package.
Those mods were obviously a non-starter for mass production.
Fun fact: I remember a dyno test where the dyno headers on an RB made 40 HP more than the race headers that fit the Cuda Stocker that engine was destined for.
Re: Big block A body and power steering [Re: topside] #3107129
01/01/23 12:39 AM
01/01/23 12:39 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Buddy of mine has a 69 383 Barracuda with power steering. IIRC, he said it took a special fitting in the steering box to route the hose away from the block/exhaust.
Re: Big block A body and power steering [Re: slantzilla] #3107202
01/01/23 12:13 PM
01/01/23 12:13 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, it is a 90 degree brass fitting that is available at any hydraulic store, Mopar didn't invent a new one, you can almost see it in this pic...
A-Body's RULE!
Re: Big block A body and power steering [Re: slantzilla] #3107370
01/01/23 10:53 PM
01/01/23 10:53 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
340 cars used the same fitting. A better solution for a non-original car is the late 70s hose that does not use a fitting on the gear.
Re: Big block A body and power steering [Re: Jim_Lusk] #3107437
01/02/23 09:37 AM
01/02/23 09:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Late '70's hose from what? I'm going to be in this situation soon and it would be great not to have to walk the face of the earth for another part!
Re: Big block A body and power steering [Re: 6PakBee] #3107746
01/02/23 05:10 PM
01/02/23 05:10 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Cordoba. Goes to Saginaw pump.
Re: Big block A body and power steering [Re: A12] #3108218
01/03/23 05:59 PM
01/03/23 05:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Quote
Mike
All 69 M code A bodies were console automatic and power steering was not available.
