Re: Big block A body and power steering
[Re: Rhinodart]
#3106854
12/31/22 02:09 AM
12/31/22 02:09 AM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
What about this statement by the OP ? The only big block A body that it wasn't available with was the "M" code A body. Also no 4spd or column shift with the M code iirc. What say the Moparts community ??? Mike
[Re: bobby66]
#3106966
12/31/22 02:32 PM
12/31/22 02:32 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
IIRC, the early 383 A-bodies couldn't get PS, but as Rhino says, that was addressed later. Pretty sure a buddy's 383/AT '69 Dart GTS had PS, but I last saw & drove it about 30 years ago. Also IIRC no PS on the 440 A-bodies, due to the larger mass of the RB; likely an interference near the battery tray or fitting the larger PS box. While the Hemi A-body drag cars got Danas, they also had offset wheels, and in the obvious case of the Darts, radiused openings to fit the resulting package. Those mods were obviously a non-starter for mass production.
Fun fact: I remember a dyno test where the dyno headers on an RB made 40 HP more than the race headers that fit the Cuda Stocker that engine was destined for.
[Re: topside]
#3107129
01/01/23 12:39 AM
01/01/23 12:39 AM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Buddy of mine has a 69 383 Barracuda with power steering. IIRC, he said it took a special fitting in the steering box to route the hose away from the block/exhaust.
[Re: slantzilla]
#3107202
01/01/23 12:13 PM
01/01/23 12:13 PM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Buddy of mine has a 69 383 Barracuda with power steering. IIRC, he said it took a special fitting in the steering box to route the hose away from the block/exhaust. Yes, it is a 90 degree brass fitting that is available at any hydraulic store, Mopar didn't invent a new one, you can almost see it in this pic...
JB Rhinehart, Realist
A-Body's RULE!
[Re: slantzilla]
#3107370
01/01/23 10:53 PM
01/01/23 10:53 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Buddy of mine has a 69 383 Barracuda with power steering. IIRC, he said it took a special fitting in the steering box to route the hose away from the block/exhaust. 340 cars used the same fitting. A better solution for a non-original car is the late 70s hose that does not use a fitting on the gear.
[Re: Jim_Lusk]
#3107437
01/02/23 09:37 AM
01/02/23 09:37 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Buddy of mine has a 69 383 Barracuda with power steering. IIRC, he said it took a special fitting in the steering box to route the hose away from the block/exhaust. 340 cars used the same fitting. A better solution for a non-original car is the late 70s hose that does not use a fitting on the gear. Late '70's hose from what? I'm going to be in this situation soon and it would be great not to have to walk the face of the earth for another part!
[Re: A12]
#3108218
01/03/23 05:59 PM
01/03/23 05:59 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
What about this statement by the OP ? The only big block A body that it wasn't available with was the "M" code A body. Also no 4spd or column shift with the M code iirc. What say the Moparts community ??? Mike All 69 M code A bodies were console automatic and power steering was not available.
