creative fuel cell holders? #310706
05/07/09 12:52 AM
05/07/09 12:52 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
anybody got a creative idea for a fuel cell holder? it's a 22 gal. rectangle -- too big to be suspended, so i gotta find some sort of cradle. i was thinking some sort of industrial (steel) bin -- something you might find behind a business.
Re: creative fuel cell holders? [Re: Scott440] #310707
05/07/09 01:00 AM
05/07/09 01:00 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Is the cell plastic or steel?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: creative fuel cell holders? [Re: HealthServices] #310708
05/07/09 05:55 AM
05/07/09 05:55 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
We basically tigged up a box with a bolt on lid and a flange for mounting all around the perimeter. Works excellent.
Re: creative fuel cell holders? [Re: HealthServices] #310709
05/07/09 03:47 PM
05/07/09 03:47 PM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
it's steel
Re: creative fuel cell holders? [Re: Scott440] #310710
05/07/09 04:16 PM
05/07/09 04:16 PM
So Cal
So Cal
With a steel tank you can easily make a recessed bracket out of angle iron and metal strap. On an old car of mine I cut a hole the size of the tank on the trunk floor. I used angle iron on all 4 edges. Then I test fitted the tank in the hole and put it at the depth I wanted and marked the tank. I used two straps bolted to the angle iron to hold it up, and two to hold it down. I think mine was a 16 gallon, but the factory uses just two straps on stock tanks.
You could also just have someone weld some brackets to the tank.
