hemi head gaskets and header bolts ? #3106833
12/31/22 12:32 AM
12/31/22 12:32 AM
s. e. pa.
calrobb2000 Online content OP
calrobb2000  Online Content OP
s. e. pa.
hi
what header gaskets does everyone like for the hemi ?
what holds up in the test of time ?
also what is the best type of header bolt to use in alu head hemi ?
thank you !
sending my headers out for jet hot coating i think , my 440 header coating is holding up fine after 5 years .
any other coatings that hold up to test of time and temp ?
Re: hemi head gaskets and header bolts ? [Re: calrobb2000] #3106920
12/31/22 11:49 AM
12/31/22 11:49 AM
N
NITROUSN Offline
NITROUSN  Offline
N
My TTI gaskets work fine along with the SS bolts. If I was to pick another it would be Remflex gaskets and ARP bolts.
Re: hemi head gaskets and header bolts ? [Re: NITROUSN] #3106959
12/31/22 02:22 PM
12/31/22 02:22 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I use the FelPro 1462 gaskets and ARP stainless 12 point header bolts
Re: hemi head gaskets and header bolts ? [Re: calrobb2000] #3106996
12/31/22 03:35 PM
12/31/22 03:35 PM
SCE graphite coated header gaskets with the longer 3/8x1.0 course thread small (7/16 wrench size six sided) head header bolts with the flange heads up scope
Put a little bit of the high temp silicone gasket maker on the threads to help them stay in for year and years wrench up
Re: hemi head gaskets and header bolts ? [Re: Cab_Burge] #3107010
12/31/22 04:06 PM
12/31/22 04:06 PM
moparx Offline
moparx  Offline
i like to use studs on any application where possible, and reduced head flange nuts.
i also cut the flange between the pipes, and drill one hole two or three sizes oversize. this allows the pipes to expand and contract as they see fit, ensuring the gasket does not tear then blow out between differences in cylinder temperatures.
i stole these ideas from member Mr. P-Body many, many years ago, and they have worked great for me since.
remflex gaskets have worked well for me.
beer
Re: hemi head gaskets and header bolts ? [Re: calrobb2000] #3107080
12/31/22 09:07 PM
12/31/22 09:07 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I have TTI headers. I don't use gaskets, just a very thin smear of rtv and locktite on the bolts.
Re: hemi head gaskets and header bolts ? [Re: calrobb2000] #3107081
12/31/22 09:19 PM
12/31/22 09:19 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Remflex #6037 are great header gaskets, they will not leak, also ARP 12 point bolts.
Re: hemi head gaskets and header bolts ? [Re: 71birdJ68] #3107092
12/31/22 10:04 PM
12/31/22 10:04 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I use Cometic gaskets and have s.s. studs with 12 point nuts.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: hemi head gaskets and header bolts ? [Re: INTMD8] #3107094
12/31/22 10:14 PM
12/31/22 10:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep, copper rtv works great.
Re: hemi head gaskets and header bolts ? [Re: calrobb2000] #3107127
01/01/23 12:26 AM
01/01/23 12:26 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Tti gaskets are VERY hard to remove. If you ever need to change them with the engine still in the car you'll hate life. They split apart when you try to remove them like the old holley carb gaskets. And they STICK
Re: hemi head gaskets and header bolts ? [Re: Hot 340] #3107932
01/03/23 10:01 AM
01/03/23 10:01 AM
an8sec70cuda Offline
Fel Pro 1462 header gasket on the driver's side. Just high temp silicone on the passengers side. I also like the TTI header gaskets.
I use the bolts that came w/ the TTI headers.
The reason I use a gasket on the drivers side is b/c the header is sandwiched in there when the motor is dropped in...can't get room to put silicone on it. Much easier for me to just use a gasket.
The passenger's side header will fall out from under the car when you unbolt it. Fairly easy to silicone it and bolt it up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: hemi head gaskets and header bolts ? [Re: NITROUSN] #3107943
01/03/23 10:23 AM
01/03/23 10:23 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
SS bolts, Not with Alum heads i hope!
Re: hemi head gaskets and header bolts ? [Re: RATTRAP] #3107954
01/03/23 10:46 AM
01/03/23 10:46 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Nickel based anti-seize with any bolt type (stainless or mild steel) going into aluminum solves the issue of galvanic corrosion
