hemi head gaskets and header bolts ?
#3106833
12/31/22 12:32 AM
12/31/22 12:32 AM
Posts: 1,999 s. e. pa.
calrobb2000
s. e. pa.
hi what header gaskets does everyone like for the hemi ?
what holds up in the test of time ? also what is the best type of header bolt to use in alu head hemi ?
thank you !
sending my headers out for jet hot coating i think , my 440 header coating is holding up fine after 5 years .
any other coatings that hold up to test of time and temp ?
Re: hemi head gaskets and header bolts ?
[Re: Cab_Burge]
#3107010
12/31/22 04:06 PM
12/31/22 04:06 PM
Posts: 19,413 north of coder
moparx
i like to use studs on any application where possible, and reduced head flange nuts. i also cut the flange between the pipes, and drill one hole two or three sizes oversize. this allows the pipes to expand and contract as they see fit, ensuring the gasket does not tear then blow out between differences in cylinder temperatures. i stole these ideas from member Mr. P-Body many, many years ago, and they have worked great for me since. remflex gaskets have worked well for me.
[Re: calrobb2000]
#3107080
12/31/22 09:07 PM
12/31/22 09:07 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
I have TTI headers. I don't use gaskets, just a very thin smear of rtv and locktite on the bolts.
[Re: 71birdJ68]
#3107092
12/31/22 10:04 PM
12/31/22 10:04 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I use Cometic gaskets and have s.s. studs with 12 point nuts.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Hot 340]
#3107932
01/03/23 10:01 AM
01/03/23 10:01 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Fel Pro 1462 header gasket on the driver's side. Just high temp silicone on the passengers side. I also like the TTI header gaskets. I use the bolts that came w/ the TTI headers.
The reason I use a gasket on the drivers side is b/c the header is sandwiched in there when the motor is dropped in...can't get room to put silicone on it. Much easier for me to just use a gasket. The passenger's side header will fall out from under the car when you unbolt it. Fairly easy to silicone it and bolt it up.
[Re: NITROUSN]
#3107943
01/03/23 10:23 AM
01/03/23 10:23 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
My TTI gaskets work fine along with the SS bolts. If I was to pick another it would be Remflex gaskets and ARP bolts. SS bolts, Not with Alum heads i hope!
[Re: RATTRAP]
#3107954
01/03/23 10:46 AM
01/03/23 10:46 AM
Posts: 2,297 NE Ohio
DoubleD
NE Ohio
My TTI gaskets work fine along with the SS bolts. If I was to pick another it would be Remflex gaskets and ARP bolts. SS bolts, Not with Alum heads i hope! Nickel based anti-seize with any bolt type (stainless or mild steel) going into aluminum solves the issue of galvanic corrosion
