Re: 1" Phenolic / Bakelite Carburetor Spacer
[Re: Kudakidd]
#3101555
12/12/22 12:47 PM
12/12/22 12:47 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Wilson Manifolds has a write up on the spacers. Not sure of the top, but a buddy that machines, builds and runs a lot of motors on his in house dyno says a 1 inch Wilson spacer almost always gains any V8 20+ hp and the 2 inch spacer gains even more.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Cab_Burge]
#3101579
12/12/22 01:28 PM
12/12/22 01:28 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Buy both and then test them on your car at the track Completely dependent on the combination.
[Re: Kudakidd]
#3101592
12/12/22 01:52 PM
12/12/22 01:52 PM
an8sec70cuda
Whats the combo? Cam, heads, intake, carb, trans?
[Re: Kudakidd]
#3101597
12/12/22 02:03 PM
12/12/22 02:03 PM
an8sec70cuda
If the intake has a the 4 hole flange, then I'd use a 4 hole spacer. If it's a dual oval hole flange...I'd be tempted to use an open spacer.
[Re: Dragula]
#3101603
12/12/22 02:19 PM
12/12/22 02:19 PM
Posts: 4,209 New York
polyspheric
New York
In a dual plane, adding a spacer allows all cylinders to get some of the flow from the opposite passages, like a small plenum (larger version of cutting down the left-right separator). Low speed vacuum may drop. but peak power goes up. More of my comments here: http://victorylibrary.com/mopar/intake-tech-c.htm#dp
Boffin Emeritus
[Re: Kudakidd]
#3101873
12/13/22 11:14 AM
12/13/22 11:14 AM
Thumperdart
State of confusion
I've done lots of testing and as stated it's totally dependent on the combo and the plastic ones are not the best in terms of heat during heavy street driving. The phenolic composites are nice and actually keep heat out of the carb(s) by up to 35* on my stuff and the wilson tapered are so far the best at least for me....
[Re: Kudakidd]
#3101895
12/13/22 12:19 PM
12/13/22 12:19 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Is the 4 hole better or worse than the fully open hole? Or does it not make a difference. Putting this under my carb to raise the shaker bubble. Dumb ebody knob question , why does the shaker bubble need to be raised ?
[Re: JohnRR]
#3101954
12/13/22 02:46 PM
12/13/22 02:46 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
Is the 4 hole better or worse than the fully open hole? Or does it not make a difference. Putting this under my carb to raise the shaker bubble. Dumb ebody knob question , why does the shaker bubble need to be raised ? My guess would be that it has the wrong shaker baseplate on the car, or the engine mounts have sagged and the engine is sitting too low. But those are just pure speculation.
[Re: JohnRR]
#3102422
12/14/22 10:25 PM
12/14/22 10:25 PM
Posts: 7,861 Witness Protection Program
Kudakidd
Is the 4 hole better or worse than the fully open hole? Or does it not make a difference. Putting this under my carb to raise the shaker bubble. Dumb ebody knob question , why does the shaker bubble need to be raised ? I miss ya too Jahnnny. lol
