1" Phenolic / Bakelite Carburetor Spacer #3101548
12/12/22 12:21 PM
12/12/22 12:21 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Is the 4 hole better or worse than the fully open hole? Or does it not make a difference. Putting this under my carb to raise the shaker bubble.
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101554
12/12/22 12:43 PM
12/12/22 12:43 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
For a street car...better. The open one will want more rpm to work effectively.
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101555
12/12/22 12:47 PM
12/12/22 12:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wilson Manifolds has a write up on the spacers. Not sure of the top, but a buddy that machines, builds and runs a lot of motors on his in house dyno says a 1 inch Wilson spacer almost always gains any V8 20+ hp and the 2 inch spacer gains even more.
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101569
12/12/22 01:17 PM
12/12/22 01:17 PM
Buy both and then test them on your car at the track wrench twocents
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Cab_Burge] #3101573
12/12/22 01:24 PM
12/12/22 01:24 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I did this, and the open spacer has always worked best for me. Even on a dual plane intake....
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Cab_Burge] #3101579
12/12/22 01:28 PM
12/12/22 01:28 PM
an8sec70cuda Offline
iagree Completely dependent on the combination.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: an8sec70cuda] #3101590
12/12/22 01:49 PM
12/12/22 01:49 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Thanks for the responses everyone. I don't think I'll be doing any track time w/ this Cuda. It ain't a show poodle, but too valuable to bust stuff (well, except for the 4.10 Dana). lol
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101592
12/12/22 01:52 PM
12/12/22 01:52 PM
Whats the combo? Cam, heads, intake, carb, trans?
CHIP
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: an8sec70cuda] #3101594
12/12/22 01:58 PM
12/12/22 01:58 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Bone stock 440-4bbl. U code Cuda, w/ a 4 speed transmission.
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101597
12/12/22 02:03 PM
12/12/22 02:03 PM
If the intake has a the 4 hole flange, then I'd use a 4 hole spacer. If it's a dual oval hole flange...I'd be tempted to use an open spacer. twocents
CHIP
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Dragula] #3101603
12/12/22 02:19 PM
12/12/22 02:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
In a dual plane, adding a spacer allows all cylinders to get some of the flow from the opposite passages, like a small plenum (larger version of cutting down the left-right separator).
Low speed vacuum may drop. but peak power goes up.
More of my comments here: http://victorylibrary.com/mopar/intake-tech-c.htm#dp
Boffin Emeritus
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: polyspheric] #3101607
12/12/22 02:26 PM
12/12/22 02:26 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
there are some outstanding spacers made out of aluminum, usually the introduce nitrous and extra fuel. works very well and picks up a second or more off the ET slip up
....BAD A$$ STREET CAR.....
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: polyspheric] #3101628
12/12/22 03:45 PM
12/12/22 03:45 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Great comprehensive article, Poly! Thanks
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: an8sec70cuda] #3101730
12/12/22 09:27 PM
12/12/22 09:27 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Use a dual spacer like the intake(2 oval holes) . I run an old wooden Edelbrock spacer on my 70 440 4bl. Not sure if they still make it though.
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101873
12/13/22 11:14 AM
12/13/22 11:14 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I've done lots of testing and as stated it's totally dependent on the combo and the plastic ones are not the best in terms of heat during heavy street driving. The phenolic composites are nice and actually keep heat out of the carb(s) by up to 35* on my stuff and the wilson tapered are so far the best at least for me....
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3101895
12/13/22 12:19 PM
12/13/22 12:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dumb ebody knob question , why does the shaker bubble need to be raised ?
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: JohnRR] #3101954
12/13/22 02:46 PM
12/13/22 02:46 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
My guess would be that it has the wrong shaker baseplate on the car, or the engine mounts have sagged and the engine is sitting too low.
But those are just pure speculation. shruggy
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: JohnRR] #3102422
12/14/22 10:25 PM
12/14/22 10:25 PM
Kudakidd Offline OP
Kudakidd  Offline OP
I miss ya too Jahnnny. lol
Re: 1" Phenolic / Bakelite Carburetor Spacer [Re: Kudakidd] #3102552
12/15/22 01:26 PM
12/15/22 01:26 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I've tested alot of spacer combos at the track and the open spacer has always worked best for me.
I usually keep my carbs on the smaller side - I like 750's and 850's.
Perhaps with a bigger carb results may differ.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
