Wheels screws #3100131
12/06/22 02:10 PM
12/06/22 02:10 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys, I wanted to get your opinion by no means do I have any type of a high horsepower car I would say 375 to 400 at most. However, I’m running a 10 5. 28 slick right now just for mock up however, they are good I’ve never taken it to the track with slicks only with drag radios
My question to you is, do I really need wheel screws with that amount a horsepower footbrake 3000stall converter a body
I am running tubes
Thank you guys, Mopar, or no car
Re: Wheels screws [Re: RAY1969CARS] #3100149
12/06/22 02:56 PM
12/06/22 02:56 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Probably not, but if the slicks hook up on the track surface you could spin the tire on the rim.
Re: Wheels screws [Re: RATTRAP] #3100158
12/06/22 03:15 PM
12/06/22 03:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Better safe than sorry.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Wheels screws [Re: BloFish] #3100169
12/06/22 04:28 PM
12/06/22 04:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Only if you are running tubes.
Doug
Re: Wheels screws [Re: dvw] #3100184
12/06/22 05:24 PM
12/06/22 05:24 PM
CA.
CA.
Re: Wheels screws [Re: RAY1969CARS] #3100192
12/06/22 06:08 PM
12/06/22 06:08 PM
New York, USA
Chargerfan68 Offline
New York, USA
I say yes with tubes. If the slick spins on wheel, it could /will pull tube and rip off air stem valve. That’s why I run screws.
When I run dragradials, the tires move atleast a couple inches. You can mark them to check. Imagine slicks at the track on sticky surface.
Re: Wheels screws [Re: Chargerfan68] #3100195
12/06/22 06:36 PM
12/06/22 06:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd run screws, one less thing to worry about...heck, I was doing that at 460 HP & footbraking a 3,000 lb car.
Re: Wheels screws [Re: topside] #3100196
12/06/22 06:43 PM
12/06/22 06:43 PM
CA.
CA.
Thanks guys !!!!!! Have a great Christmas. Hope all your projects get done.
Re: Wheels screws [Re: RAY1969CARS] #3100200
12/06/22 06:59 PM
12/06/22 06:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Take some white shoe polish and put a small dab on the edge of the rim and tire, if it moves install the screws scope wrench
I think I used #10x3/4 inch long course threaded sheet metal type screws with a 6 sided hex head to make it easier to install and remove up scope
I had used regular head screws in the past, Phillips and standard straight cut in the past until I switched wrench
I inflate the tires up above 25 Lb. and use a small drill bit a little smaller than the body of the screw to drill the rims and a short way,(3/5 to max of 5/8 inch) into the tire bead to allow the screws a good start into the beads wrench
IHTHs
Re: Wheels screws [Re: Chargerfan68] #3100328
12/07/22 09:27 AM
12/07/22 09:27 AM
an8sec70cuda Offline
iagree If you're running tubes, I'd be using screws.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Wheels screws [Re: an8sec70cuda] #3100331
12/07/22 09:35 AM
12/07/22 09:35 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I ran them for years ... my car has had between 520- 550 hp motors in it a few years ago I switched to drag radials and I now no longer screw the tires to the rims , I checked and the tires aren't moving on the rims plus I didn't want to drill holes in my new rims . I agree though with slicks and tubes they should be screwed to the rims or run a beadlock style wheel .
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Wheels screws [Re: 11secdart] #3100484
12/07/22 05:50 PM
12/07/22 05:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Use Grade 8 stuff (Moroso or equivalent)
Drill and tap the holes, using an extra screw(s), before installing the tires.
Screws are only good for one or maybe two uses. The tire beads dull the point and they won't want to go in, resulting in pulling the treads out of the wheels.
Apply pressure and run the screws in by hand. Use JB80 or equivalent.
I have wheels that have had a dozen sets of tires on them and the holes are still 100% doing this.
Re: Wheels screws [Re: CMcAllister] #3100493
12/07/22 06:31 PM
12/07/22 06:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Back in the old days when I screwed my slicks to my wheels I had a small drill bit with black electrical tape on it. The tape was set as a stop so I could drill slightly into the slick so my screws with into the slick and didn’t try pushing the slick away from the wheel. I use high tac now but then again I Dont run tubes.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
