Wheels screws
#3100131
12/06/22 02:10 PM
12/06/22 02:10 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi guys, I wanted to get your opinion by no means do I have any type of a high horsepower car I would say 375 to 400 at most. However, I’m running a 10 5. 28 slick right now just for mock up however, they are good I’ve never taken it to the track with slicks only with drag radios
My question to you is, do I really need wheel screws with that amount a horsepower footbrake 3000stall converter a body
I am running tubes
Thank you guys, Mopar, or no car
Re: Wheels screws
[Re: RAY1969CARS]
#3100149
12/06/22 02:56 PM
12/06/22 02:56 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Probably not, but if the slicks hook up on the track surface you could spin the tire on the rim.
Re: Wheels screws
[Re: dvw]
#3100184
12/06/22 05:24 PM
12/06/22 05:24 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: Wheels screws
[Re: RAY1969CARS]
#3100192
12/06/22 06:08 PM
12/06/22 06:08 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I say yes with tubes. If the slick spins on wheel, it could /will pull tube and rip off air stem valve. That’s why I run screws. When I run dragradials, the tires move atleast a couple inches. You can mark them to check. Imagine slicks at the track on sticky surface.
Re: Wheels screws
[Re: Chargerfan68]
#3100328
12/07/22 09:27 AM
12/07/22 09:27 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I say yes with tubes. If the slick spins on wheel, it could /will pull tube and rip off air stem valve. That’s why I run screws. When I run dragradials, the tires move atleast a couple inches. You can mark them to check. Imagine slicks at the track on sticky surface. If you're running tubes, I'd be using screws.
Re: Wheels screws
[Re: an8sec70cuda]
#3100331
12/07/22 09:35 AM
12/07/22 09:35 AM
Posts: 4,981 new jersey usa
11secdart
new jersey usa
I ran them for years ... my car has had between 520- 550 hp motors in it a few years ago I switched to drag radials and I now no longer screw the tires to the rims , I checked and the tires aren't moving on the rims plus I didn't want to drill holes in my new rims . I agree though with slicks and tubes they should be screwed to the rims or run a beadlock style wheel .
Re: Wheels screws
[Re: 11secdart]
#3100484
12/07/22 05:50 PM
12/07/22 05:50 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use Grade 8 stuff (Moroso or equivalent)
Drill and tap the holes, using an extra screw(s), before installing the tires.
Screws are only good for one or maybe two uses. The tire beads dull the point and they won't want to go in, resulting in pulling the treads out of the wheels.
Apply pressure and run the screws in by hand. Use JB80 or equivalent.
I have wheels that have had a dozen sets of tires on them and the holes are still 100% doing this.
Re: Wheels screws
[Re: CMcAllister]
#3100493
12/07/22 06:31 PM
12/07/22 06:31 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Back in the old days when I screwed my slicks to my wheels I had a small drill bit with black electrical tape on it. The tape was set as a stop so I could drill slightly into the slick so my screws with into the slick and didn’t try pushing the slick away from the wheel. I use high tac now but then again I Dont run tubes.
